Hi
I've always loved the look of the standard pipes but I missed the sound of that V4 growl so I've decided to modify my baffle with great results.
Firstly i cut to the inner side of the end welds with a 1mm cutting disc
[image: 20151123_171132 (4) (Copy).jpg]
Then pulled the baffles out in one piece using some grips
[image: 20151123_171931 (6) (Copy).jpg]
I then cut all of the pipes from both of the end plates
[image: 20151123_174305 (5) (Copy).jpg]
and then ground the end plates flat from any welds
[image: 20151123_194111 (4) (Copy).jpg]
I then welded the original pipe hole up (centre) and made 2 new 33mm holes in it to match the opposite end plate
[image: 20151206_121209 (Copy).jpg]
I then inserted 2 x 32.7mm perforated tubes and welded them to the end plates
[image: 20151206_150340 (Copy).jpg]
[image: 20151206_132232 (Copy).jpg]
I then wrapped the perforated tube in proper baffle wadding (sorry I forgot to take a pic of this) and reinserted the baffles and welded up.
[image: 20151207_190154 (4).jpg]
[image: 20151209_180803 (4) - Copy.jpg]
I then Sand blasted the whole exhaust ans sprayed in high temp black paint
[image: 20151209_190735 (2) (Copy).jpg]
[image: 20151209_190756 (3).jpg]
Refitted heat shields and then refitted to the bike
[image: 20151219_160246 (5) (Copy).jpg]
[image: 20151219_165822 (Copy).jpg]
[image: 20151219_165833 (5) (Copy).jpg]
The results were just what I was looking for, you can hear the lovely V4 sound but without it being too loud
