Gp Shift - Has Anyone Figured Out How To Do It?
15 posts Started 11 Jan 2016 Last recovered post 14 Jan 2016 Wayback Machine snapshot 25 Jan 2016
I would love to have my VFR shift pattern be the same as my race/track bike just to avoid having shift issues on
race day.  I'm wondering if anyone out there has figured out how to reverse the shift pattern on their Gen 8.  I wish
it was as easy to do as it was on my GSXR but the shift rod is entirely encased on this VFR which probably means
a lot of work and a lot of money.
Just curious if I'm the only one who wants to do this.
Thank you!
Ironically, some people use a VFR linkage on other bikes to achieve that.
ISTR people swapping in CBR shift parts?  Many Honda parts are interchangeable.  But, you may need the CBR rearsets, too, which would be a problem on the 5th and 6th gen--not sure about the 8th.  Good luck.
Do 6th gen rear sets work on the 8th gen?
This may be a source of a shift rod that can mounted to achieve GP shift
Sato makes rear sets for the 6th Gen
Why not buy a quick shifter and mount the input shaft connection upside down?
The rear sets are identical, as far as I can tell, between the 6th and 8th gen bikes, so I imagine the Sato (and other) 6th gen rear sets should work fine.
This is exactly why I grafted a 6th gen lower cushion onto my 5th gen track bike project... so I could flip the shift rod hook-up and add a quick shifter  :fing02:
Do you think I'd have to buy a Gen 6 Quick shift to do that or would the Gen 8 Quick Shift work?  I'd have to look at that to get a visual but I like the way that sounds as a possibility!  Thanks for the idea!
The 8th Gen quickshifter compresses while upshifting.  If you flip the linkage, the upshift would put the quickshifter in tension, so you would lose the functionality.  Supposedly liter-class CBR or RC51 rearsets will bolt up to a 6th/8th gen after enlarging the mounting holes a little.  You'll have to play with the rod length, but I'm pretty sure 900/929/954 rods are shorter than the RC, which would be more desirable in this situation.  Not speaking from experience, just after quite a bit of research since I was in the same boat after getting my VFR years ago.  Decided to live with the standard shift pattern on the VFR after getting rid of the track bike.
I purchased CBR929 rearsets with the intent of modifying for the 6th gen mount. The 6th gen mounting hole spacing on the rearsets is asymmetrical with the left & right spacing being different while the CBR are the same spacing.  The Center to Center spacing is different also so this will have to be adapted for to get them to work. The shift rod length looks like it should work.
Ya'll are awesome!!   I am really starting to feel confident that this might actually happen!!  I can already see that my weekend will be spent in front of this laptop looking at rear sets and shift rods  :)
Please keep that ideas and tips coming as they are greatly appreciated!!
Welcome to the forum... there's a great bunch here.  It's traditional to post up a picture of your VFR and a little intro...
...otherwise, you don't exist
Agreed but he was looking for a quick fix reverse shift.
There is no "quick fix" ...... I've built enough rear set/gear linkage set ups to see that this is simple but does require some fabrication
To reverse the action of the lever you need to use 2 clevis rod ends, a Z linkage and a new shift lever, taking the g/box lever from 12 o'clock on the shaft to a lug at 12 o'clock on the lever
The new shift lever has to pivot on something
You could drill the foot peg hanger and put a pivot in that, but you still have to make lever and linkage, so not so quick
PS clevis rod ends are really cheap and easily available, once it's up and working OK then that's when to get some steel in the lathe and make some fancy fittings
Here's a link to someone else's work with 6th & 8th gen parts...
http://www.vfrdiscus...everse-shifter/
End of thread · 15 posts recovered Wayback Machine snapshot 25 Jan 2016
