HI guys and gals
A few questions on powder coating:
For coating of frame and swingarm, what needs to be protected from the coating and what's the best way to do it?
I'm thinking that threads and bearing surfaces are the obvious things, but there may be others?
If I want to keep the elf pro-arm plate on the swing arm, what's the best way of keeping that un-coated?
For the headstock bearings I was going to just leave the outer races in place and then knock them out post-powder coat. Maybe do the same with the swing arm bearings?
For the threaded stuff, what's easiest? Find suitable bolts to screw in place and leave? Or maybe there's some flexible compound that could be squeezed into the bolt holes and removed afterwards?
What about the big hole in the SSSA that the rear is installed into? Is there enough slack in that not to worry about the thickness of coating?
I also presume that if I want to drill a brake hose hole in the rear swing arm (as others have done), I should do it before the powder coating? Slightly off topic, but what diameter have others used for this hole?
TIA
Malcolm
