Just thought I'd share how dave has set my bike up for me.
Dave has been in nz running clinics and I was chuffed when he used my bike to show basic suspension setup during his appearance at a club gathering.
My bike was stock settings as per manual at the front --- fourth line showing for preload and 1 turn from hard rebound so the punch and reference marks match.
When he bounced the front, all gathered could see the return action was real slow. After a couple of tries, he set the rebound at plus half turn softer. Now the action was even down and up and resettling just once. No oscillation.
At the back, the true lack of balance showed when he bounced the shock -- it went bounced up and down a few times. My preload setting was at the stock setting, seven clicks from full soft. But the previous rider had slacked off the rebound a fair bit I realize now. ( don't know how much as I assumed it was stock because I saw that the punch marks aligned when I got the bike.)
Out with the screwdriver and Dave finally settled on what I found to be 1-1/2 turns out from maximum hard on the shock rebound screw. Setting as per manual is 3/4 turn out from maximum hard.
On bouncing the bike from the middle to check if the front and back was working in unison, he decided the rear preload at seven was too high and softened it to four clicks from softest setting.
As time was short, he did not measure sag with me on board, but I am about 65kg geared up and he reckoned it would be all good.
Just those simple tweaks has transformed the bike for me. It feels tauter and more stable whether on the straight or in the turns, particularly smoothening out the long sweepers. My grip on the bars has relaxed considerably as the bike is so much easier to control and my wrists don't feel the strain as much in comparison to the before settings.
It also felt like the transmission was slicker with gears snicking into place up and down smoothly. Felt like the engine had a bit more punch to it but Dave explained that as "being able to get on the power a bit more quickly as the bike was more stable!"
- [image: Attached File] image.jpeg 104.63KB 13 downloads
