Ripped A Wire To The Brake Light Connector
12 posts Started 8 Mar 2016 Last recovered post 12 Mar 2016 Wayback Machine snapshot 13 Apr 2016
I was a bit ham-fisted and managed to break the wires on the VFR's rear brake light.   [image: IMG_0059_zpsivwwanz3.jpg]   How do I get the pins out of the connector so that I can re-solder them? Naturally, the wires broke off flush with the connector, so I can't solder them the way they are now. :rolleyes: I tried pushing them through with a pick and pulling them through with pliers, but neither seemed to work and I didnt' want to ruin the connector.   This brake light is always on, so I can't get the bike inspected while it's FUBAR.
From the front of the harness plug, you should be able to slide a very thin jewelers screwdriver or something similar between the plug and the spade connector and release the locking tab.  Then you should be able to pull the connector out from the back.
Short of having a dedicated tool, dental tools can also be used.  They're useful for other jobs as well.  In particular I've used them to straighten radiator fins.   They can be had on Amazon, ebay and some surplus stores have them.
http://www.amazon.co...ds=dental tools
So I bought this Lisle kit and I'm still struggling to get the damn connectors out. :unsure:
Those connectors can be a pisser even with the right tool. Patience will go a long way here. Man, I sound like Yoda.
Is the locking pin on the top and bottom of each terminal, or the sides?
My VFR is still under winter storage so it will be difficult for me to check. If you look close enough into the connector you should be able to see where the tabs are that hold the pin in the connector.
Or if you know of a dentist retiring soon, just ask for dibs on the tools.  Most of the time they end up at the curb on bulk pick-up day.
Good video.   The last time I ordered from Tightwad, I had him send me some spare connectors and spades for times when the tab breaks off and needs to be replaced.
+2 one broke .
End of thread · 12 posts recovered Wayback Machine snapshot 13 Apr 2016
