Hello all, I figured I would share this with my fellow vfr riders :)
I purchased the clear signals for front rear and brake light from a british company. They claimed it to be british made, but I noticed it came out of Germany. Not sure about that one.
Putting that aside, I'm pretty happy with the rear end now, but dissatisfied with the front product- it doesn't seem to fit right and it didn't come with LED's, instead what I got was two amber bulbs with single terminals which wouldn't fit my oem 2 terminal sockets. From what I know Europe doesn't allow for running lights so they don't use the second terminal.
The rear is nice and bright , but during the sunny day is rather hard to see as expected against the clear/white housing.
I wired in a generic electronic flasher relay to stop the hyperflashing and bought a JDM Astars LED pair for the front. These are white running lights with amber turn signal option. The way I figured I'm allowed to have front facing white lights, and they do illuminate the front very nicely. The only gripe I have with these is it takes a half second to 1 second for them to illuminate after using turn signals or just turning the ignition on. I also installed a generic flasher for the brake light that I've used for a while and it works fine.
I emailed the seller letting them know the front needs work but the rest seem alright. If I could have it my way I would have bought the clear housings only for front and rear signals and brake, and reused all of the oem sockets and got some LED's of my choice as you have more options that way, and the price tag would likely be $100 or under rather than almost $300
I have some LED headlight conversions coming in mid-week and will update you all on how that turns out. I can't stand the halogen yellow with the white LED running lights on the front end, so it will have to go!
[image: post-29102-0-92326600-1457981750.jpg]
[image: post-29102-0-68191500-1457981773.jpg]
[image: post-29102-0-66928100-1457981783.jpg]
[image: post-29102-0-63515200-1457981794.jpg]
[image: post-29102-0-64152500-1457981798.jpg]
[image: post-29102-0-26544000-1457981814.jpg]
[image: post-29102-0-81744300-1457981824.jpg]
[image: post-29102-0-85429400-1457981831.jpg]
[image: post-29102-0-37324100-1457981837.jpg]
Edited March 14, 2016 by SnowCrash
