Rothmans Resurrection - Bringing The Ultimate Barn Find Back To Life
32 posts Started 16 Apr 2016 Last recovered post 26 Apr 2016 Wayback Machine snapshot 29 Apr 2016
So last year, another member on here and myself got wind of a bike that had been sitting for a while, and discovered it was available. Needless to say, he jumped at the chance. The first post in this thread are the pics taken by the previous owner of the bike as it sat. Overall looks pretty solid, but definitely will need some work to get it back to fully operational status :)
[sharedmedia=gallery:images:73646] [sharedmedia=gallery:images:73645] [sharedmedia=gallery:images:73647] [sharedmedia=gallery:images:73648] [sharedmedia=gallery:images:73649] [sharedmedia=gallery:images:73650] [sharedmedia=gallery:images:73651] [sharedmedia=gallery:images:73652] [sharedmedia=gallery:images:73653] [sharedmedia=gallery:images:73654] [sharedmedia=gallery:images:73655] [sharedmedia=gallery:images:73656]
Wow what a find. Looks good overall. Edited 16 April by MRbaker
Very awesome :)
We actually had the bike running the first day he brought the bike over. We did a quick carb clean (more on that later) and valve clearance check, new battery and it fired right up :) Gotta love a Honda :)
[sharedmedia=gallery:images:73695]
After that, the parts started coming off...
[sharedmedia=gallery:images:73663]   First up, the brakes. They were definitely needing a thorough cleanup.   [sharedmedia=gallery:images:73657] [sharedmedia=gallery:images:73658] [sharedmedia=gallery:images:73659]
They did seem to clean up OK though :)
[sharedmedia=gallery:images:73660] [sharedmedia=gallery:images:73661] [sharedmedia=gallery:images:73662]
Nice!  Very cool.
Looking forward to following this. Hope you plan to keep posting. Great find!
The bike is actually pretty much done, I'm just now trying to gather up and document the whole process. Some things will probably be out of order, but I'll add notes about what we did :)
This was the first pic I took of the bike on the lift the day it showed up...
[sharedmedia=gallery:images:73666]
The mismatched black and gold wheels needed to be corrected. White wheels suck to keep clean, but they seemed like a better fit for this bike. Another RC30 rear wheel was put in place while the gold rear was sent off with a VFR750 front for powdercoating.
[sharedmedia=gallery:images:73697] [sharedmedia=gallery:images:73698]
So the bike was flipped around on the lift, and the front end taken off. The bike's owner cleaned up the top triple clamp and fork bottoms. Race Tech fork springs were added, as well as SKF forks seals from Jamie Daugherty. One of the oddball things about the RC30 is that the forks have compression and rebound damping adjustments, but no adjustment for preload. :wacko:  That was fixed by adding a set of fork caps from a GSXR750. We'll probably have to give the bike some anti-rejection medication from this point forward for adding Suzuki parts, but they're both Showa.
[sharedmedia=gallery:images:73673] [sharedmedia=gallery:images:73672] [sharedmedia=gallery:images:73669] [sharedmedia=gallery:images:73671]
While the front end was off, the steering head bearings were also replaced. The refinished upper triple clamp and fork legs definitely look a lot better now :) And, there's adjustable preload!
[sharedmedia=gallery:images:73694]
The RC30 is formally known as the VFR750R. Since it's a VFR, it's also susceptible to the traditional wiring issues :)  We found a crispy stator connector and starter solenoid connector. No problem, just needed a custom VFRness made up, and also got the stator connector kit at the same time :)
[sharedmedia=gallery:images:73702] [sharedmedia=gallery:images:73688] [sharedmedia=gallery:images:73696]
Speaking of wiring, at some point the temp gauge must have been disconnected or replaced and some custom work was done to the wiring harness with wire nuts :wacko:  That was also sorted out.
[sharedmedia=gallery:images:73700] [sharedmedia=gallery:images:73699] [sharedmedia=gallery:images:73701]
After the front end was back together, it was time to flip the bike around and get to work on the back.
[sharedmedia=gallery:images:73685]
All the rear end parts were taken apart, cleaned, greased, and reassembled.
[sharedmedia=gallery:images:73689] [sharedmedia=gallery:images:73684]   The RC30 came from Honda with safety wire on the sprocket nuts and center axle nut, so that was also redone when the back end went together.   [sharedmedia=gallery:images:73687]   New fancy gold boinger   [sharedmedia=gallery:images:73686]   After that, it almost started looking like a motorcycle again.   [sharedmedia=gallery:images:73675] [sharedmedia=gallery:images:73679]
The cooling system was also gone through, replacing the thermostat and radiator cap mostly due to age. All the hoses were checked and seemed OK, but the radiators needed some fin work. That definitely took some time, but they should flow air a bit better now.
[sharedmedia=gallery:images:73681] [sharedmedia=gallery:images:73680] [sharedmedia=gallery:images:73682] [sharedmedia=gallery:images:73683]   The carbs were a bit of a mess when we first took it apart, but we got them clean enough to get the bike running. Turns out they needed more than just cleaning since they were leaking pretty bad, so new float valves and petcock rebuild kit from NRP was ordered, and a complete gasket kit from LiteTek   [sharedmedia=gallery:images:73667] [sharedmedia=gallery:images:73668] [sharedmedia=gallery:images:73677] [sharedmedia=gallery:images:73676]
I wish I had a fraction of the skills (and garage) required to do something like that.
Great find and looks like a very thorough job. :beer:
The bike didn't have turn signals on it when he got it, so we were looking for something better than the huge factory blobs, but less tacky than the typical stick on winkers. I sourced a set of Chinesium knockoffs of the RVF style turn signals, similar to what the JDM RC30 came with originally. The rears mounted up OK with a set of unobtanium original brackets, but we had to figure something out for the front since these are surface mounted on the NC35. I ripped the stalks from a set of 3rd gen blobs, and used those as spacers. Seems to work OK.
[sharedmedia=gallery:images:73693] [sharedmedia=gallery:images:73691]   After all the mechanicals and electricals were sorted, it was just a matter of cleaning everything up and putting it all back together. The paint cleaned up VERY well, I'm going to miss this bike when he comes to fetch it :sad:   [sharedmedia=gallery:images:73690] [sharedmedia=gallery:images:73674] [sharedmedia=gallery:images:73670]
Now all that's left is the shakedown ride, so hopefully I'll have pics of the bike to post tomorrow of the bike out in the wild :)
Great thread...awesome that this bike is going to be ridden again after a long rest...
I feel a little guilty about picking it up, but I know that it will eventually make it back into the Evl stable... :thumb:
Love it
I'll give you $5 Australian for it 😊
Good to see another RC30 being brought back to it's former glory :fing02:
Just beautiful. Lots more pics please.
Looking good!
The orderly placement of the parts for the brake rebuild made me especially happy. Lol
Looking good!
Seb, did you see the carb pic? That one took a bit more time :)
Road test is complete :) I didn't want to put too many miles (KM) on it since it's not mine, but it runs every bit as good as it looks :)
[sharedmedia=gallery:images:73704]
And it looks damn good...
Wow, perfection.....great job, it pays ta be a little on the OCD side. Great thread
Oh Jesus Christ!!!!!! This is a thing of beauty. Geeeeeez. Congrats and please give us as many detail as humanly possible.
C
Beautiful.
Well done! :beer:
It's a '88 with KM clocks but big headlights and no J-spec frame badge...where did it come from?
But in any case it is a beautiful bike and lovingly restored!
Love it.
And the rebuild process - so meticulous and clean.
I envy your skills.
Beautiful work!
And my OCD side was quite happy with your parts pics :)
The only clue to the bike's origin is the headlights, they are the large globe style which points to the Italian market. Looking at the bottom of the tank, it was originally standard colors. I had heard stories of the all white "ghost" RC30's which some had converted to Rothmans livery, but this tank was once blue and white. I have no clue where/when the bike was converted to Rothmans paint, but it's definitely a professional quality paint job. Jim Granger did some touch up/repairs to the bike several years ago.
Fantastic find and great restoration job!
Rollin
I take it it doesn't have a 17-digit VIN?  If it did, it could only be a Canadian bike starting: JH2RC302...  Check Rick's RC30 site if you're keen to do more sleuthing.  I had thought most markets had "big" headlights, apart from Japan and, er, New Zealand?  There are some other clues hidden on the bike, but you'd have to have access to the back of the headlights, and the back of the instrument cluster (might be too late for that!)
That is probably the best looking RC30 I've ever seen. Terrific work.
VIN is non standard.
Evl had done a fair bit of sleuthing on this bike, but we'd definitely like to know more about its history...
If anyone on here has owned or seen it in the past, please chime in. Edited 18 April by Baketech
Are these links permanently broken, or will they be rebuilt?
End of thread · 32 posts recovered Wayback Machine snapshot 29 Apr 2016
