Thanks guys. I got back out to it this morning and I can't seem to find any play in the thing. But I haven't really applied much leverage yet. I'll pull out the tq wrench and make sure everything is within spec. I guess I'll be buying a 46mm socket. :D
I was talking to my Dad about it today *Father's Day and all* and it occurred to me that while the I don't notice lateral play during regular riding I have felt something odd twice. Both were under emergency situations of a similar nature.
I've noticed it happen when I was in a left turn and I had to slow quickly. During both of those corners I was really hanging off the bike and I had to rapidly decelerate and change my line. When I did that it felt like the rear end stepped out towards the muffler like the bike wanted to induce a drift. Well I mean that's kind of what I'm doing to it in the corner anyway but she slides out more than I'm telling it to.
Other than the wheel bearing or swing arm pivot bushings, is there any possibility that the rear shock or other worn pieces could cause the tire to push out toward the muffler under suspension compression? Like the bottom of the tire moving toward the muffler and the top of the tire away from it. Like \ under compression.
At the beginning of this season I cut my spare muffler down from 18" to 9" and a while back I noticed the bolt that attaches the muffler to the passenger foot rests was missing it's nut. It only came to my attention as there were tiny gouge marks on my rim near the hub of the rim at a similar location to where my 9" muffler stops. At that time I assumed the muffler had move towards the rim and caused contact. Now with the possibility of lateral movement I'm wondering if the rim (rather than the muffler) moved the distance. :(
I cannot recreate contact between the muffler and the rim under suspension compression while the bike is stationary.
Here is the damaged rim. These marks were not there last year. Granted as I mentioned the muffler nut had fallen off that secures is to the rear passenger peg. I can't see how anything other than the muffler could have made contact. And no, sadly I didn't hear or feel anything out of the ordinary when it occurred.
[image: IMG_5559_zpsnfhciuej.jpg]
vvvvvvvvvvv That looks to be a good deal of play. :0 vvvvvvvvvvv
[image: IMG_5563_zpsbhrzznmd.jpg]
*EDIT*
I went at the bike with a pry bar this afternoon to get some more leverage. I had someone else hold the bike steady and tried to walk the swing arm around. I couldn't produce any movement. I also pulled out the tq wrench and got everything tight to spec. Nothing was lose. The only thing that looked odd was as space on the rear shock mount. It had a bit of a gap, though the bolt was properly torqued. *See picture below. I also snapped a pic of the rim lug nuts. Are these the oem ones?
[image: IMG_5565_zps8rxsdclu.jpg]
[image: IMG_5691_zpssphqdgwl.jpg]
And for those that stuck it through to the end. This is what that experiment exhaust can sounds like.
[video: https://www.youtube.com/embed/U21qpGmjZdw?feature=oembed]
