Tyga rearsets
25 posts Started 12 Jul 2016 Last recovered post 17 Jul 2016 Wayback Machine snapshot 10 Jul 2017
Just installed Tyga rearsets for the CBR 900 rr on my 4th gen, fits very well. Just had to lengthen the rod on the brake MC,
use the gearclamp for the  NSR 250 MC 21, and shorten the gear rod about 5mm.
Can't use the brake light switch, because it will rest against the headers, so it is necessary to use a pressure switch.
Really nice rearsets![image: 20160707_194342_1468319053968_resized.jpg][image: 20160708_155104_1468319065801_resized.jpg][image: 20160708_092458_1468319062430_resized.jpg][image: 20160708_092514_1468319059671_resized.jpg][image: 20160707_194005_1468319056633_resized.jpg]
Those are nice too, did you have to mod anything?
The shift linkage should be at a 90* and 90* angle. That looks like maybe 100* and 120* from here, not really terrible, but it doesn't look ideal. You might be able to fiddle with it (lengthen the rod by a half inch or so) a bit to tighten both the angles up to 90-ish degrees, without putting your toe in a weird spot.
2 hours ago, stryker
Not that I remember. I had to order a longer shifter rod from Sato Racing, and turn the rear brake master cylinder 180 degrees to fit, but that's because of the exhaust I'm running, and a few of the other mods I've done to my VFR. They weren't hard to mount, and offer a good range of adjustability. The knurled foot pegs are nice and grippy!!!
Well i was a little fast on the trigger here. Went for a testdrive, gearing up works fine gearing down works to 4th gear, then i won't go any lower. Interesting start uphill from the petrolstation. Tried different adjustments with no luck.
Again, the angles should both be as close to 90 degrees as possible.......      :beatdeadhorse:   :goofy:
{ you need a longer rod}
I hear you, got pretty close to 90 i would say.  any longer rod and the gear lever will be way too low.[image: 20160712_190554.jpg]
4 hours ago, CandyRedRC46
That's what she said!
Who? The nun to the bishop?  :-)
16 hours ago, stryker
That looks much better!
Looks better, but still doesn't work.
stryker with rearset linkage having each linkage at 90deg to each other is optimal but should work even with less angle. You say even with current pic setup it's not shifting some gears, well to me that gear shaft spline linkage doesn't have enough leverage & also looks weak so your probably getting allot of FLEX with next to no leverage. For example know brands like vortex that use same linkage system lever but on piece billet which would create more leverage so more movement. Vortex sell parts separately & there gear spline linkage for say the CBR1000RR will fit your setup & probably fix the problem you have & it also suits the knuckle you have on the shaft as same as what they use.
This is link to pic of vortex rearsets & you will see the shaft spline linkage https://www.google.com.au/search?q=VORTEX+CBR1000RR+REARSETS+PIC&client=firefox-b&tbm=isch&imgil=lBZPWdd-_jjzCM%3A%3BBbAch__9c16UlM%3Bhttp%253A%252F%252Fwww.revzilla.com%252Fproduct%252Fvortex-adjustable-rearsets-honda-cbr1000rr-2008-2015&source=iu&pf=m&fir=lBZPWdd-_jjzCM%3A%2CBbAch__9c16UlM%2C_&usg=__VhBYQ7C2Qhd5H1GJZPzdz55u-Zc%3D&biw=1548&bih=843&ved=0ahUKEwifq96NyPDNAhUGp5QKHRYkA2AQyjcINg&ei=b0SGV9-3A4bO0gSWyIyABg#imgrc=lBZPWdd-_jjzCM%3A
Thanks! Will check it out.
Heres a pic of the gear clamp i'm using.
[image: gearlink-c8f00bf3.jpg]
I have CBR900 rearsets on my 3rd gen and they work very smoothly. I'd almost bet the problem you have is where the lever(s) are touching somewhere they shouldn't and so stopping you from down changing.... Just need to investigate what's happening there I think!
[image: image12_zps2qri9erc.jpeg]
No touching anywhere, can't really find anything that's causing this problem, everything is lined up. What rearsets are those? Could post a pic of your gear clamp?
11 hours ago, TheStig
Man that is a slick looking third gen! I love the FTP license plate lol.
21 hours ago, stryker
They're just Ebay rearsets for a CBR900. These ones, I think: http://www.ebay.com/itm/CNC-Silver-Rearsets-Footpegs-For-Honda-CBR900RR-919CC-SC33-1996-1997-1998-1999-/131444219225?hash=item1e9aaf9d59:g:7kUAAOSwNSxUy01o&vxp=mtr
I used a different clamp than that supplied, though.
Here's a pic from when I was mocking it up to fit, before I realised the heel plate was better fitted upright, to avoid the swing arm.
I also had the shift upside down in this picture  & your's looks as if the shift is upside down too - try turning the clamp 180 degrees... I think it may  fix your problem.
If the rod touches your sidestand pivot you may have to bring the rod's connection outward like I did, but looking at your's - you might be OK!
[image: DSC_3941_zps4e6d5da3.jpg]
The rod clears the sidestand pivot. If a flip the the gear arm 180' i will get a reversed shift pattern which i don't want. But i can always try it out and se how it works.
GP shift it like god intended. Standard shift is for pleebs.
Is it the 11th amendment, thou shall gp shift.
stryker, 7/15/2016 at 5:37 PM
No, if you flip the arm so it points upwards, you'll get normal shift pattern.
The close up I have above is of a race shift pattern, which I did by accident when mocking up the rearsets. Easy mistake to make.
Forget the comments about race shift, you don't need that on a VFR for the road.  :goofy:
Then you have a different set up, with the rod linked above the gear lever, not under as mine. No i won't be using gp shift, just gona try it out to see if it works that way.
It's simple mechanical engineering... I'm trying to help you here!
Look at the above close-up picture I posted carefully and imagine the movement when you push down on the lever.
Then if you're still unconvinced - compare with a picture of a standard shift lever (Which points BACK, not forward!) and you should be able to see.... the close up pic above is 100% set at race shift.
If you want normal shift you'll need to flip the arm to vertical. I checked on my bike and it confirms this.
Yes of course, that's correct, my bad. Been messing so much back and forth, that i'm starting to thing backwards  :comp13:
End of thread · 25 posts recovered Wayback Machine snapshot 10 Jul 2017
