Oh good. Battery stopped charging and i broke down.
31 posts Started 31 Jul 2016 Last recovered post 5 Aug 2016 Wayback Machine snapshot 26 Aug 2017
It's a fun, fun time as i'm sure anyone who has broken down knows.
Thankfully, the AA were with me inside 20 minutes, they gave the battery a bit of juice, and i was home 15 minutes later as i'd broken down about a mile from home after a brief 50 mile ride out on my own.
I should have noticed the early warning sign in my heated grips turning themselves off (a power saving feature when it thinks the ignition is off), but i certainly noticed stuttering when idling a few miles later.
It's on charge now, so i'll at least be able to get in to work, where i can charge it fully, then load test it. I'll also test the charging system on the bike to see where the issue is.
Working in a motorbike garage does have advantages ;)
My Problem was the voltage regulator!
This is why all VFR800's are supposed to be fitted with a voltmeter and FH020aa/SH847 regulator rectifier by now.
Indeed.
I've got a new after-market RR coming tomorrow, which has better wiring and connectors etc.
There's a voltmeter i want, but postage from the US to the UK is a good 120% the cost of the item, so that's out the proverbial window... And there's no European supplier and nothing on eBay.
Don't waste your time with that. A generic $3 waterproof ebay voltage readout will do much more good than a simple red/yellow/green led.
That steady green range is huge and worthless and the steady amber range is tiny, while being equally worthless.
1 hour ago, CandyRedRC46
Or a SH775 and now there is SH875.
I have heard that the SH775 was not designed for high rpm use, that it should only be used on engines with a redline below 10,000 RPMs. Also the SH775 can only handle 30 amps with proper cooling, while the FH020 and SH847 are good for 50 amps. I installed an SH775 on a friends zx6r and I can tell you that it made considerable heat compared to the FH020 on my VFR800. I think the SH775 on a VFR800 would be highly stressed, while the SH847 on a VFR800 would live a much happier and easier life.
2 hours ago, hellindustries
Indeed.
http://www.ebay.com/itm/Digital-Voltmeter-DC-4-5-30V-RED-LED-Waterproof-Car-Motor-Motorcycle-Panel-Meter-/321350650042?hash=item4ad1fdc8ba:g:KIAAAOSwwPhWk1eo
Something like this would provide much more useful info.
I've been looking at something similar.
I figure i could attach it to the back of the ignition. to keep it looking tidy without making any cuts in to the fairing.
Where's the best place to wire it in?
You are going to want to wire it straight to the battery, fused and with some kind of switch, either a simple push button or something more complex like a relay (powered by battery with a switching current from a head or tail light). I just used a simple push button switch and wired straight off the battery.
5 minutes ago, CandyRedRC46
Righto.
I'll get one ordered this week.
I did what Candy described, installed a relay to control power direct from the battery through a fuse to the relay, then on to the voltmeter. The relay is powered from the tail light feed. I installed my voltmeter in the steering head, used a cheap garden hose fitting to make an adaptor that just pushes snugly together. I armoured the wires against chafing as they enter the bottom triple clamp with some vacuum hose.
[image: IMG_0992.JPG]
I shall be doing similar, but placing the voltmeter as another user did, like so:
[image: volt1.jpg]
The criticism I have of my VM position is that it is hard to read in sunlight. If you set the voltmeter further down in the darker recesses of the fairing you'll have a better chance of reading it more easily.
A fair point. I'll see what i can do when the unit arrives. And of course: Pics or it didn't happen ;)
Just a point on where to place the Voltmeter.
Honda made a dogs breakfast of the Earth system on the VFR and I would put it that many regulator fails happen when the earthing goes intermittent stupid so I suggest you wire the volt meter not to where it will show ideal condition of the battery but into the muck I call the green wire common earth harness maze.  I wired between the positive ignition lock connector block and picked a random negative green wire connector elsewhere.  On turning on the ignition the voltage shown is lower than battery voltage but it shows a circuit under load. Just use a multimeter to measure a healthy ( engine running and not running tests) at battery Volts +/- and compare to voltmeter +/- and that's your baseline.
I had a proof of concept a few months ago after I had done some work on the bike.  Went for a ride and the voltmeter was all over the place when I was at steady RPM.  Seems I had done one of the most common sources of regulator fail. A loose negative battery terminal.   My 5$ 1" voltmeter just paid for itself.
http://www.ebay.com.au/itm/252365106169?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
New RR on today. Back to usual service.
Still need to get my low-beams working. I know it's not the switches, at least. Probably not the bulbs, but may be either the relay or some corrosion on the loom-side of the connectors to the bulbs. My money is on the relay.
May also try out some LED bulbs for the brake lights. The one i've put in the front parking/side light is doing well. Nice and bright.
CandyRedRC46, 8/1/2016 at 3:05 PM
46,000 miles on my SH775 with no heat and no failures, I am installing one on the RC51 Friday.
Thats good to hear. It should be even happier on the rc51 too.
hellindustries, ‎02‎/‎08‎/‎2016 at 6:25 PM
Which RR did you buy? I got one from wemoto.com made by electrex, I got one of these cheap Chinese voltmeters like Terrys, must get it installed soon.
51 minutes ago, hellindustries
Part: RR881
Hi -- I am not meaning any kind of offense --I apologize to say,  but you couldnt pay me to put that R/R on my ride.....
Jes I think that's probably the same or very similar to the one I fitted, is it crap?
13 hours ago, mello dude
I know right? For that price he could have got a real r/r like an FH020aa. Or spent a tad more and gotten the SH847.
Note the use of stator to rr connector and the lack of DC to battery fusing!
Also definitely not MOSFET, let alone series.
15 hours ago, Saoirse32
Yep..
It was what i could get next day. And for less than the advertised price. I NEED my bike every day. It's my only transport.
So, given the time constraint, it was the best option.
Supposedly Electrix is made in the UK and makes good stuff, but that rr screams Chinese garbage. Hopefully you'll get a few years out of it before you have to go through this again.
They are and they do.
We use them in the workshop from time to time. When needed. Quality is always good, customer service is top-notch. We've had no problems over the years.
It may not look fantastic, but i'm confident in the actual quality of the unit. And even IF something goes wrong with it, i know it's backed-up with a warranty and support.
They do their own R&D, i know that much. These units are for more than one bike, so concessions have to be made. I would have liked direct plug and play, but again; Time constraints.
If i'd have had the time, i'd have gotten a mosfet R1 RR and done the mod. I just can not have the bike off the road for a day, let alone several plus...
You don't want direct plug and play, the rr to stator connection is a failure point. You want to solder that connection.
YMMV...
My plugs are still in perfect nick since 1997...
End of thread · 31 posts recovered Wayback Machine snapshot 26 Aug 2017
