What does this do? Cable into lower right engine case . .
6 posts Started 9 Aug 2016 Last recovered post 11 Aug 2016 Wayback Machine snapshot 26 Aug 2017
Noticed this when having a sqizz at the underside yesterday - seems like it's frayed enough to be in danger of getting damaged.
What is is and can I just cover it in sugru or should I replace?
[image: IMG_20160808_200357.jpg]
That's the neutral light switch !
Mine looks the same and has for 4 yrs
I'll seal it to be sure - cheers for that guys
The fraying is just the outer heat/anti-chaffe cover, it is fine the way it is. DO not you sealant on the connector to cable (i.e. around the frayed area) the heat cycling will draw in any moisture via the cover & start to corrode the connector. As it is it is self venting & mine has looked like that almost from the factory & definately for the 6 years I have owned the bike. Leave it alone !
ah  .. . duly noted
End of thread · 6 posts recovered Wayback Machine snapshot 26 Aug 2017
