Check exhaust temp
4 posts Started 7 Sep 2016 Last recovered post 15 Sep 2016 Wayback Machine snapshot 25 Aug 2017
I can only see the two at the front - what's the best way to get somewhere I can point an infra red temp guage at the rears?
Remove the heat shield by your right foot, you can then see both rear headers.
If you are looking to get the temps of the header pipes as they come out of engine you should be able to shoot an infrared reading from the back on the chain side.  I've been able to shoot directly at the headers from there, and you may be able to see the header pipes as they route to the exhaust can behind the heat shield.  Just look over the chain guard near the front.
End of thread · 4 posts recovered Wayback Machine snapshot 25 Aug 2017
