2 hours ago, RhodeMoto
Greetings - New to VFR and forum. I recently acquired a 1991 VFR. One owner, but came via another party so do not have direct access to past history. Bike is not quite as nice as Treestylist,... 70K+ miles. Did come with extra set of wheels and front float rotors (from 4th gen?), as well as a box of misc. air filters, oil filters, manuals gave some hope it was owned by responsible person. Also has a FOX rear shock, so thinking owner did have right idea in mind. Was a great deal, but had to buy - no ride. Had anticipated a complete go through. Had not anticipated bent fork tubes.
Responding to this thread as it is new and thought if some parties could help me it may help Tree man.
No intention hijacking thread,....
I have now read through many past forums on suspension and looking for sage advise.
I have new tubes on order with Frank's -
Have all new bushing, seals, head bearings.
Made a stem nut adjust tool so if anyone local needs to borrow can do.
Have head reassembled but trying to find an ounce spring scale to adjust to the Honda spec of 1-1.5kg pull at leg.
In tear down have discovered that this has RaceTech 1kg/mm springs with a preload made from a thin wall electrical conduit,...not to thrilled with that part.
These may be on the stiff side as rider weigh in at 165, no luggage?
It has RT compression gold valve with a set up for their "C33" stack - NO bleed hole?
Not clear if the rebound piston is stock or RT? It has 10 17mm dia. x .01 mm shim stack. - NO bleed hole.
Can someone explain what the bleed hole does as it seems to me that the top of rebound piston has a (by-pass) valve that would allow oil to be forced to the top side that can not go though the compression stack and therefore "Bleed"oil to the top side?? What would have been the result of this being used without the bleed holes? IT must have worked to some degree? I only rode it for a very short distance when loose head bearing (result of whatever happened to forks?) came to light. I did notice it seemed to dive badly on braking.
Have called RT to see if they could provide original info from owners name,..They have name in record but no spec's. They are nice but answers are cryptic at best. They suggest that I order a complete new shim set at $60+ and with that get a new "code" to get set up for me. Not unreasonable but think that this set up could be close to correct. I just want to verify the rebound stack - my understanding is that if the rebound is still stock then may not be adequate for the stronger springs and be overpowered on rebound. What the logic is of the bleed holes and should I add these to both compression and rebound?
How is it that no one seems to have put together a spreadsheet of RT data so we can do are own calculations? Would love to hear from 3rd gen owner who have RT set up and any clues of what works and what does not.
If this should be placed elsewhere (or new thread) on forum let me know?
Hijack thread. Fallowing as well. I'm all about any info I can get on my pretty bike. I do not have the education you guys do on parts I have a mechanic as a best friend that does all the heavy thinking for me. I'm just in it for the ride and injoyment of this wonderful machine
