The 5th gen bible, when removing the front sprocket tells you you have to drain the clutch fluid and remove the slave cylinder to gain access.
I was thinking, provided you don't crack the seal on the gasket, can you do this without having to drain the clutch fluids?
Yep, easily.
Remove the slave cylinder separate and wrap a thick rubber band around it to prevent the piston coming out.
Nice. After the last time i did it i thought there had to be a wait around it. I bloody HATE bleeding the clutch on this bike. Always dramas.
A zip tie also works well if you can't find a large enough rubber band.
Simply use a brake hose clamp and crimp the hose before removing the slave cylinder
I used one of these. The plastic swiveling heads line up perfectly with no scratches or scuffs to worry about. Easily held the piston in and did not lose a drop.
[image: clamp.jpg]
Crimping the hose will not keep the slave cylinder in as its being forced out by a spring. As others have said a G or spring clamp as per above pic are the simplest & quickest solution. Remember to clean out any accumulated crud from around the slave cylinder & whilst its off, pull the clutch actuation rod out, then clean & lube it to ensure a nice smooth clutch action.
Are you supposed to do this with the 6th gen as well? Coz I did not do that when I dropped a tooth in the front.
31 minutes ago, Blazerdman
NOPE
dont remove the slave from the sprocket guard (unnecessary), and definitely do not drain the clutch to replace a sprocket
I'm baffled by this entire thread. I went up a tooth on my front sprocket a couple years ago and never even thought about messing with draining the clutch.
