Lug Nuts
12 posts Started 21 Dec 2016 Last recovered post 28 Dec 2016 Wayback Machine snapshot 25 Aug 2017
Are Gen's 5 & 6 lug nuts interchangeable? :unsure:
They are not only interchangeable, they are identical, as are the wheels themselves.
Thank you Auspanglish!
Interesting though that the parts #'s are different on PartsZilla.
One must understand what those part numbers are referring to... As the model of motorcycle changes so too does a part of the reference.
Nonetheless, it is known amongst VFRologists that they are identical.
Ok. Good. Thank you VFRologists Auspanglish! :beer:
53 minutes ago, MysteryRider246
The part numbers for the wheels or of the lug nuts?  Part numbers can change due to a paint or finish change, but still fit.
The early nuts (3rd-5th gen) are longer, but the axles/studs are the same.  Strange.  Maybe the wheel flange thickness is different on the 6th gen?  The early nuts should fit all bikes; not sure about the later nuts...
I owned the 5th and 6th gens simultaneously for a couple of years and could swear I had interchanged rear wheels and lug nuts and that there was no difference.
Maybe my memory has gone a little mammary!
Anyone know what the torque spec is on 5th gen lug bolts?
17 minutes ago, Epyon007
It's 108Nm for the 4 wheel mounting bolts.
End of thread · 12 posts recovered Wayback Machine snapshot 25 Aug 2017
