Ignition switch Clean rebuild
7 posts Started 11 Jan 2017 Last recovered post 13 Jan 2017 Wayback Machine snapshot 10 Jul 2017
Turned key on this morning to go to work and nothing! Thought battery was dead but I moved the key and everything came on and engine started. Is there a known issue with ignition switch and can it be taken apart and contacts cleaned or do I need to get a new switch??  Has only happened once but I don't like surprises.
Cleaning the switch may or may not solve the problem long term. A new switch is about $40. I replaced one last year in my 212,000 mile ST1100.
when you replaced the switch where you able to rekey to match your other locks?
I didn't replace the lock. Just the switch. What bike do you have?
Oh good news. Did not know you could just replace the switch portion thought it was an assembly. sounds like the easy most reliable option. Thanks for the info.
Honda calls it a "contact base".
End of thread · 7 posts recovered Wayback Machine snapshot 10 Jul 2017
