Hi folks,
I started the charging system rejuvenation process last year. My system was working perfectly 12.5-13v at idle, 13.8-14.1v at 1500 RPM & 14.4v at 5000 RPM, but I wanted to insure against future problems.
My stator-R/R plug (3 yellow wire) was getting hot, but not yet burned so I cut that out and soldered & heatshrinked the wires. No heat in the wires now.
Then I bought a mosfet R/R and installed that. It came with a "kit" of 12 gauge wiring, a new 3 yellow wire plug and a weather-proof 4 terminal plug for 2 red and 2 black 12 gauge wires (1 red & 1 black directly to the battery). When I cut the original R/R harness, I put 1/4" spade terminals on both sides of the cut and matching connectors on the new R/R wiring for an easy roadside swap if it was ever necessary. (I have read stories that not all of these are as reliable or long-lived as they should be and I didn't buy the "name brand". My decision, you may decide different.) That's when the trouble started. Idle voltage was 13v, then 13.8v at 1500-2000 & 13.8v at 5000 RPM.
When I unloaded her after the big move, I went for a ride to get gas only to need a boost at the gas station. I found the 3 yellow wire plug had come undone. Aha, I thought. But no, even after a charge and a ride a week later it still cranked over slower than normal.
Yesterday I put the meter on it and watched it intermittently lose charge. Hmmm, then I watched the 3 yellow wire plug and saw an occasional arc. One of the terminals had pushed out a bit the last time I connected it at the gas station. I fixed that, but DAMMIT, 13.8v is still not right!
So I thought about it and realized that the spades in the weather-proof plug that came with it were less than 1/8" wide. Why didn't I think about that before - nowhere near big enough. This also explains why the wires connected directly to the battery made no difference to the voltage received by the battery.
This morning, I went out and snipped out the plugs - both of them. They weren't necessary anyway since I had the 1/4" spades in there for emergency use.
I reconfigured the connectors and got 13.8v at idle and 14.2v at 5000 RPM. Then I connected the extra red & black wires directly to the battery and now have 14.2v at idle and 14.3-14.4v from 1500 all the way up to 5000 RPM. So, those 2 wires to the battery are worth 0.5v over the stock harness.
This morning I started to do The Drill ( http://vfrworld.com/forums/showthrea...2131-The-Drill ) until I was sure I had no stator or R/R trouble. I also read through Jeff Barrett's write-up on the charging system of his 6th gen ( http://vfrworld.com/forums/showthrea...ectrical-Loads - great job, Jeff).
The moral of the story is to go with a mosfet R/R, 12 gauge wire, connect the extra red and black wires directly to the battery and do the 3 yellow wire fix.
Cheers,
Glenn
