Hey All,
I took off and replaced my emblems today. Just in case anyone else is interested:
Took an Amazon gift card – 30 mil thick plastic card - and pressed the flat edge diagonally down against the gap between the emblem and the gas tank. Sorry, I didn’t think to take pictures while the emblems were still on the tank.
The emblems have a pretty much vertical edge and the gap between the edge of the emblem and tank is pretty small but with a little muscle, the card will eventually work its way underneath – gradually added pressure to the card and when the card finally got under the edge of the emblem, there was an audible popping sound (each time).
I then pushed the card further under the emblem and gently pried/lifted it away from the tank. The emblems are held on by two sided thin foam tape and came away pretty clean.
If you have a thinner plastic card, maybe 20 mil or so, I think it will be easier to work under the edge of the emblem.
I’ve always preferred the Honda Wing logo as a decal/sticker rather than an emblem so I may add a wing later on, this one has a clear backing/background.
The OEM emblems around about 62mm in diameter and the backs are pretty much flat (logo surface being convex). The ones I replaced them with are 60mm and size-wise fit pretty good.
