Hi all
I have seen somewhere that someone had a problem with vibration which resulted in selling..
I have struggled with the same problem for a long time which I have finally resolved!!!
I discovered that one of the oxygen sensors was fouled which caused cylinder 1&2 to run leaner than 3&4 !! Also check & clean the reed valves! ! This also causes throttle response issues.. silky smoothe now!!!!!!!
12 minutes ago, Silvo
Hi all
Silvo, do you have an 8th gen? This is the 8th gen subforum but your profile says you have a VFR1200? Glad to hear you resolved your problem though.
