If anyone was wondering what 21 year old coolant tools like
16 posts Started 13 Jun 2017 Last recovered post 20 Jun 2017 Wayback Machine snapshot 20 Nov 2017
WOW! You may want to try flush out the engine, if that was in the cooling system, who knows what's in the cylinder cooling jackets, that's pretty nasty stuff there!
Looks like you have a lot of work before you can try to start it. :goofy:
Yeah I was and I noticed no water was coming out of the water pump area, so I pulled off the coolant rail and the whole pipe was clogged, and it still it I wasn't able yet to clear it
Sent from my R1 HD using Tapatalk
You coud try to bypass the rad and water pump with a external water pump or directly water from a hoose... That engine should be nasty inside.
How do I replace the impeller on the water pump? Is it pressed on?
According to the service manual it is suggested that the water pump is replaced as a unit. The part 19200-ML7-692 is listed for $119 on Partzilla.
The cooling system on my ST1100 was going the same way after 10 years standing; the thermostat was the worst (basically it was dissolving), but I had a couple of pinholes on the radiator as well. fortunately they've sealed and held up fine for 20,000km using some cold weld goop. Once I had a sealed system, I ran some radiator flush suitable for aluminium parts through the bike for an hour, then dumped that and replaced with coolant.
[image: IMG_2440.JPG]
Man, throw some WD-40 on that and move down the road [image: emoji6.png]. Good luck to you my friend...it'll be a journey for sure!
11 hours ago, nicholas042416
Seafoam! Cures anything... :goofy:
KevCarver Seafoam! Cures anything... :goofy:
Silly me, of course a little sea foam and it's ready for a 2000 mile road trip!
Lol why don't I put it together now and do a cross country road trip
dirtriderLol why don't I put it together now and do a cross country road trip
Water pumps are overrated anyways...
Basically, just added weight
dirtriderBasically, just added weight
Keep us updated on this restore, looks fun.
End of thread · 16 posts recovered Wayback Machine snapshot 20 Nov 2017
