RS850 Replica
109 posts Started 7 Oct 2017 Last recovered post 21 Nov 2019 Wayback Machine snapshot 6 Jul 2020
I've started to build a RS850 replica from a VF750F chassis and using a VFR750 RC24 engine.
I've replaced the front end with one from a Triumph T595, using this one as it's one of the largest right way up fork set up with full suspension adjustment, I had to extend the steering stem but the bearings are the same size, I'm also having a new top yoke made with a step down to give more fork length. Installed CBR600 front wheel, disc's etc and made some brackets to install a set of 4 pot Nissin's, using Brembo master cylinders for both the brake and clutch.
I've installed the RC24 engine (due to the RC15 engine being shot) with a little frame mod, I had to remake some engine mounting bracket and still have to make the rear one, I'll probably wait untill I've sorted the exhaust out. Tack welded some bracing in around the head stock, started to make up some brackets for the the coils , ECU etc. I've cut and welded some brackets for the rearsets.
At the rear I plan to replace the rear shock with a new adjustable one, I've installed the CBR600 rear wheel and have started to make up the bracket to hold the rear Brembo caliper.
I'm hoping to be collecting some copies of genuine RS850 body work over the next few weeks, but have only just started to look out for a fuel tank as I don't like the look of the standard VF one and the VFR one doesn't fit very well.
I will try and post updates if anybody is interested in the build.
[image: _MG_0188.jpg]
[image: IMG_1705.JPG]
[image: IMG_1707_LI.jpg]
[image: IMG_1706.JPG]
[image: IMG_1709.JPG]
[image: IMG_1710.JPG]
That is an epic project, I'm sure there will be many people watching this.
Congrats.
I really like the forks.
The Triumph forks look butch enough, but even better if you can paint them that grey/green colour and a set of Showa stickers.
Good luck, and keep us posted on your progress.
Yes I agree about the forks, I'm planning to try and machine the ridges off them and get some Showa stickers, I would have liked some correct forks but those are out of my budget range. Spent a good couple of hours yesterday making the rear caliper bracket out of 10mm thick aluminium plate trying to mill external radius's by hand (not an easy job).
I'm off to Stafford classic bike show this weekend coming up to see what goodies I can get, i'll be looking at petrol tanks mostly.
That´s will be a hell of job ; impressed !
Good idea the upper gull wing triple!
Will be looking forward to seeing more progress.
[image: mMedmh3.gif]
And I thought there was something wrong with me doing a swingarm swap to the VF.... You're doing a transplant! Awesome, going to be watching progress.
Yep, this is cool
17 hours ago, trooper1999
No doubt they'd be $$$ - if you could even find a set. Gotta love the QD axle clamps - Honda used them on the RC30 as well.
But don't sweat the pricey mods, I really like the idea of creating a replica using only a modest budget. Best wishes on your project.
That's so cool
Sent from my LG-H918 using Tapatalk
19 hours ago, Forbes
What swinging arm are you using in your swap? have you photo's?
Todays update, Managed to obtain a VFR400 NC30 fuel tank but not sure about it's use, it looks about 50mm (2") short might have to look into getting it extended or the standard VF tank altered, I will have a chat the a guy I know which he thinks is going to be easier.
Also attached a photo of the rear caliper bracket just needs some modifications to it and the caliper to allow it to clear the wheel
[image: IMG_1722.JPG]
[image: IMG_1723.JPG]
How well do any of those tanks fit with the RC24 airbox in place?
Neither fit with the air box in place I plan to make the whole area above the front cylinder and onto the carb top casting and the underside of the tank a air box, as it's not planed to be used on the road .I'm not too worried about using no airbox
17 hours ago, Lorne
And the early CB1000F "Big One".  Very long forks--I have a pair somewhere.  But they are otherwise not at all the same as the RC30's!
1 hour ago, JZH
I've had my eye out for some time for some "Big One" forks.   Haven't even come close.
1 hour ago, trooper1999
Got it.  Had a feeling it wasn't an issue.
Cool idea. I removed the right side "cage" and left side boss from the frame for my VFR swingarm swap...no worries.
Quite some project!!!
:lurk:
That looks bloody amazing - will be watching with interest.
Huge respect for anyone tackling projects with a limited budget. It means you have to think a bit more and be creative.
Godspeed!
Stray
Hi, I've had a busy week at work so not been able to do much to the RS this week and next week will be even worse, but just to give you an update, I've made some progress on the fibre glass front, met a great guy at Stafford show who has a Genuine RS850 and he was very forth coming with info about the genuine bike, he said he may be up for me to get copies of his body work made. Managed to get the rear brake caliper fitted just need to make a mounting arm for the caliper. started work on the exhaust pipe, oh my life the rear isn't going to be easy, I'm going to order some pre-made bends and other parts and try and mock up a system, still on with making small brackets for this and that, going to order a pair of alloy VFR400/NC30 radiators and that will mean more brackets.
Looks like a long night on the internet shopping is in store for me.
Has anybody got any ideas on trackday tyres 120/17/17 front, 160/60/17 rear
Looks like one of those labor of love things. :beer:
It's either a labour  of love or the owner need psychiatric help  :491:
Not managed to get much done this week, managed to get the rear brake and wheel sorted and all spacers made up.
Started to order exhaust bends to get on with that, made a little headway with the bodywork but nothing definite yet, I will make the rear exhaust as a temporary job and alter it later if needed, I just need to get some stainless wire for my MIG welder, I'm going to tack it together and then get it TIG welded up.
My plan is to get the engine running in this frame by the end of the year,  I'll post some more photo's when there is more progress to see
Hi All, I've had a good result today and managed to get hold of a genuine seat for a RS850, collected it today and the same guy says he has a fairing that he would sell as well but he needs to dig it out, I'll try and get some photo's of the seat in a 1st fitting later this week.
I've been really busy with work so not managed to get anything done over the last few week, but hopefully things should start to move a little. Friday I managed to get a start with the rear exhaust, but part way through ran out of gas for the welder, so I spent a good couple of hours sorting that out.
I need to get my finger out and get some work done or this will take me for ever
Nice work so far. The mechanical talent on this forum is beyond words. Good job!
Just a few photos of the seat placed onto the rear of the bike
[image: IMG_1751.JPG]
[image: IMG_1752.JPG]
[image: IMG_1753.JPG]
[image: IMG_1754.JPG]
did I spot an FZ750 in bumblebee paint?
Yes for my sins I have these in the garage
[image: P1020393.JPG]
[image: IMG_0155.JPG]
56 minutes ago, trooper1999
No sin to have a few FZ´s arround, I would like one to!
Great looking bikes I think!
Sure looks like it.  Bolt pattern for taillight (LED!!!) matches.
So cool!!!!!
This tread is brilliant. Your seat has some racing pedigree. Surely that adds about 10hp to the bike!?
Stunning these old pirt still arround, wounder where the rest of the bike is?
Nice find fo sure!
I think I've been bad, I have just bid and won these on evil bay, it will involve JUST a little more work to swap the complete front end AGAIN
But they will look a lot better and more in keeping with the time line, so all the work to make the longer steering stem and caliper bracket is now not needed and I will have to make the lot again, hopefully the steering stem will be OK but just got to wait until they are shipped from the USA.
[image: forks.jpg]
It will be a bolt-on for the VF750 frame and the steering stops look nearly identical, both on the frames and lower clamps.
So, same calipers you had, with some new custom brackets?
Gold Valve Cartridge Emulators and eliminate the TRAC?
VFROZ, 10/7/2017 at 5:39 PM
but not much travel, eh ?
I've not had much chance to get anything done for weeks (works keeps getting in the way, oh the joys of being self employed) Just a quick update then, I've managed to get the VF1000R fork and yokes in, along with the wheel and spacers made to get the wheel centered, I need to sort out the clip on's, and make the new brake adaptors.
[image: IMG_1804.thumb.JPG.95fbf00eb11376e522f518f923fb11b8.JPG][image: IMG_1806.thumb.JPG.93146015b70ac79edb9f3b31975f5ea7.JPG]
I've started to try and teach myself TIG welding and have made a start on the rear exhaust, I need the pig tail in it to gain the length, I've just ran out of argon so that's my next job, get more argon. I'll try and get some more done and more posted.
[image: IMG_1802.thumb.JPG.ce0490d55c83eb1268b82be952add50c.JPG][image: IMG_1803.thumb.JPG.e4b3ff1d3684276ddc4714c2e92f6c31.JPG]
What are you using to cut the tubing, if I may ask?  I recently acquired a really cool vertical, metal-cutting bandsaw (two of them, actually, but I'm only keeping one!) because cutting metal has always been a massive headache for my fabrication projects.  Very ambitious to start TIGing on a complex exhaust system, but I'm reminded of a van Gogh quote: "I am always doing what I can't do yet, in order to learn how to do it."  (I'm of the same view...)
53 minutes ago, JZH
I like that.
A well tuned bandsaw is a great way to cut tube. What kind of saws did you get? PM me if you like
Sorry nothing as high tech as a band saw only an old fashioned hacksaw with a fine toothed blade in it, and a little bit of filing after to get the edges to meet better, I'm off work today, with everybody else at work I can play most of the day so am getting on with the rear exhaust, I'll post a couple of pics later, writing this with a cuppa tea in my hand. who said men can't multi task?
Gotcha, I was just noticing the little gaps, same as I always got from hand-sawing, which in theory make welding more difficult.  But it's good to see that you can compensate for this by spending a bit more time on the filing.  In any case, you're doing well!
Hi @trooper1999
I'm very interesting about your project ! I tried myself to put an RC24 engine into RC15 frame but I found one major problem.
As you can see on this picture in an other thread RC24 engine in RC15 frame the chain sprocket output shaft is much higher than the stock one (approx 5 cm). Without major modification on the RC15 frame to lower the RC24 engine I cannot align it with the swing arm center bolt pattern. The result is that the chain is sliding too much on the swing arm. More RC24 covers are touching the lower square tube of the frame both sides.
How did you solve this problem ?
Best regards,
Hi I have lowered the engine into the frame as low as possible, by re positioning the lower engine mounts, an other issue is that the output shaft is shorter on the RC24 than  the RC15 engines. It's still a bit high but should be ok
Thanks for that info I'll have to have a good look at RC30 sprockets when I'm ready, I've had quite a good but frustrating week with the Tig welding, some of my welds are ok but some will need tidying up, I've been having trouble welding the rear 2 into 1 joint piece so I've given in and it's gone off to the professionals, started on the front now, I've got one side made up with only slight modification from the standard, I will start on the other hopefully tomorrow and try and get them both into the 2 into 1 collector. I'm just ordering more bends now but it looks like they won't be here until mid next week. I've been looking at silencers and have found these on evilbay has anybody had any dealings with them.
 https://www.ebay.co.uk/itm/LEXTEK-GP1-Matt-Stainless-Steel-GP-Stubby-EXHAUST-Silencer-51mm-Slip-On-End-Can/152273850553?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Just note that the RC30 sprockets are narrower than the modern VFR sprockets (not sure about your model), for 525 chains rather than 530 (apparently also called "chain 50" sometimes).  And there may be other OEM sprockets out there (that's my graphic, btw); those were just the ones I found in the JT sprockets catalog, I think.
Well thank you for your efforts, I saw it after Seb mentioned the RC30 sprocket for my VF project, I always save things of interest and value....brain is not what it used to be....if it ever was.....haha
You're welcome.  That's what it's for.
Shiny bit arrived today
 [image: 5a6b347550d2a_newshock.thumb.jpg.5b61c0930d7f2f9c981f0105f9187014.jpg]
Nice one!  bought one for my VF500F2 couple of years ago
[image: P8269514.jpg.c594d16846b7a410441a73463b5ede2e.jpg]
How have you found the YSS shock, I've not had much dealings with them, but they have good reports.
I've been very pleased with it (put in RaceTech srintgs and emulators upfront).
I dealt with a man who is an highly regarded suspension guru and works as a consultant for YSS too, visiting the factory in Thailand regularly.  The OEM unit is thoroughly shagged...
[image: P8269509.thumb.jpg.5bd95a696eb334863885e77b07afffa5.jpg]
He had the compoments inhouse so he built mine. But I am confident that what comes from the factory is as good as.
The other brands (he sells those as well) like Hyperpro, Wilbers (I had one on redslut) were dearer for what I perceive as no better quality.
[image: P8269504.jpg.4f25208c248550c2151b73f30ab363b7.jpg]
setting the shock's height
[image: P8269515.jpg.d1290e8642f577cf7d78bd37fe1b34a3.jpg]
Another YSS (his bike)
[image: P8269524.jpg.81413c326972ddcb9439c24fb1873597.jpg]
and upfront for good measure.
[image: RTGV1.thumb.jpg.d2813282358152645c9f1d46b32ee2a4.jpg]
Thx @trooper1999 for the details about your frame modification.
And thx @JZH and @Forbes for the graphic very helpful.
About the rear shock I gone for a wilbers stage 3 fully adjustable and it works like a charm, great improvement compare to the stock one. For the front a VTR1000 SP1 year 2000 ø41 fork with wheel and brakes.
Regards,
I think I'm starting to make some progress with the exhaust, I've had a good afternoon. the upper one just needs some spring hooks welding on and the lower needs the left header altering and then on to the silencers.
[image: IMG_1855.thumb.JPG.5c363d3f0341083d3b334ded42e0c51a.JPG][image: IMG_1859.thumb.JPG.5f07a04ba9a7d4ba148d5ad1ddb503b5.JPG][image: IMG_1854.thumb.JPG.9323253a732ccd5fa2caddf05f0d08da.JPG]
A little look at the new shock with the exhaust wrapped round it[image: IMG_1857.thumb.JPG.1bfd77368b219511b2eaa8ce3248a754.JPG][image: IMG_1856.thumb.JPG.2d8c4fd3b8f0279b76e9d6f4b769adc4.JPG]
Looks great. Love the look of these old bikes. This build is coming along great. +1 following
Finally managed to get a little work done on the RS today, made a ruff cut out for the lower silencer bracket, seat mount made just got to make a couple of lugs for the front of the seat.
Started on the rear caliper torque arm  (more parts ordered). I've attached a couple of photos with and without the seat fitted.
[image: IMG_1867.thumb.JPG.daaf450118a249c9b5824a820218b9c3.JPG][image: IMG_1866.thumb.JPG.dd5b31722a80814c203c988f8f615ce6.JPG][image: IMG_1868.thumb.JPG.df7ed7f21a00748156a1999408ed44b1.JPG]
Sorry all, I've not had much chance to get on line for a few weeks, but I've been pottering with the bike!
Started with the fairing bracket/clock mount, managed to get hold of a set of 125 Honda clocks (not sure what from but they look right), so I've swapped the VFR internals for the 125 ones so all should work OK, New caliper brackets made and fitted along with hoses and front brakes bled. Been on with the wiring alterations and sorting out where and how to mount various bits, ie ECU, fuel pump, starter solenoid etc, trying to cut out all the redundant wiring from the loom.
I've made some good progress with a RS850 fairing hopefully should have a answer on it by the end of May (not easy dealing with somebody who doesn't speak great English).
I'll try and get some up to date photo's posted soon.
Nice project. You are one brave and talented dood.
This build is awesome!
Hey Troop, what sort of rear master cylinder is that?
Any info would be much appreciated.
Honda CRF?? 🤔
7 hours ago, VFROZ
Hi VFROZ, Sorry but I'm not sure of the make, I bought it last year at Stafford Classic bike show for £10.00, I think it's a copy of may be Brembo, I just liked the look of it.
3 hours ago, trooper1999
I like it, might have to search around.
Keep up the good work, starting to look good.
Hi all, I think I need help! with the bike not my mental health😀 this I think applies to all the RC24 owners does the fuel pump run all the time when the ignition key is turned on, mine seems a bit intermittent it  runs some times and not others when the engine is not running, I've not had a lot of experience with these bikes so am learning on the fly, but my FZ750 pump runs for a few moments and then cuts out until the engine starts.
So I'm not sure if I've got a faulty pump or it's normal.
The "Fuel Cut Relay" should prevent the pump from working unless it is being cranked for starting or running.  It would have to be faulty or jumped to allow the pump to operate when just turning the key on and not cranking.  But I have never heard of one going bad in that way.  They usually just fail and not allow the pump to run.  Many people just bypass them, but I wire in a parallel switch so I can control when it pumps (like after storage when the carbs have been drained) or get home when it fails.  It was designed as a safety feature so the pump just wouldn't continue to operate when not wanted.
Sounds like yours has been bypassed.
The fuel pump on my 1990 ST1100 runs for 5 seconds when the ignition is switched on, then continuously when the engine is turning.
Just a little update, Friday was my day off so had a couple of hours on the RS, after a few false starts ( sorting oil leaks out that the engine didn't have last time it ran) & with a home made fuel tank we had some life, it ran for a while but I couldn't run it too long as I didn't have the radiators fitted, just got them back today from having the mounting brackets altered so just a test fitting. I have been on with altering the wiring loom mounting ECU fuse box, starter solenoid and trying to find where to put the battery etc.
just a few photo's
 [image: IMG_2025.thumb.JPG.200b480e078e5577fe24704bbc11f83d.JPG]Honda 125 ? clocks with RC24 internals, CBR switch gear.
[image: IMG_2023.thumb.JPG.f4c69b333b3cce1bff87d0dab493789a.JPG]
[image: IMG_2022.thumb.JPG.a76624514966d98af3d202c0af4b11e6.JPG]
VFR400 (NC30) radiators with mounting brackets altered, one of the next jobs is the oil cooler, either re mount the standard or sort new one, it should look like this though.
[image: 470769791_RS86006101_LI.jpg.aa683bde3bb576a442aa7e99978bf51a.jpg]
I've been busy today I've made some oil cooler take off adaptors and am fitting a cooler
[image: image.jpg]
[image: image.jpg]
Nice progress!  It's gonna be so cool.
Sorry guys been a while but I've just collected a few new bits,
starting to fit but here's a couple of picks of the first fitting
[image: IMG_2281.JPG]
[image: IMG_2282.JPG]
[image: IMG_2283.JPG]
[image: IMG_2284.JPG]
Wow! Bodywork is looking great!
The body work is a copy of the original RS850 parts, I managed to get a set from a guy who has 2 RS's and have had a set of moulds made so I'm now the owner of a correct set of body work, all I have to do is get them to fit better.
I have done the seat and opened out the hole for the rear silencer so that's done, been trying to get the fairing to fit this morning, but it's been on and off, cut a little, refit, and then start it all again, it must have been on and off about 10 times today, trying to get it in the correct position before I make the mounting brackets, oh the joys of making a bike.
Really cool build. Can`t wait to see more.
Hi All, Today's been a good day, had a phone call to pop a couple of towns away to collect a interesting part from a metalworking GOD, just got home and co
uldn't wait to trail fit it, He has cut and welded the VF750 tank removing the mass of pipework that is the standard fuel tap and filled the hole, he then cut off the original filler cap and made a twin filler setup, I got two alloy filler caps (from a Kawasaki I think) for the endurance look,  he also fitted a VFR400R tank breather,.What do you all think?
[image: IMG_2541.thumb.JPG.51994272d7da31b7ec563d3f35ae75aa.JPG]
[image: IMG_2540.JPG]
I need a cigarette now...  :tongue:
I think I agree with Dutchy.  Pretty fucking cool.
So you think I've got the right sort of look then?
A few other bit I've been on with:-
Battery box made and mounted on left hand side of engine, remounted starter solenoid along side battery box.
A pair of ruff fairing side mounting brackets along with finished top fairing bracket.
Fitted VTR1000 fork stantions and internals to VF1000r bottom legs.
Vents cut out into seat unit and started to prime and fill any little imperfections.
Cut up the standard VFR airbox to use the mesh part at the base.
I'll try and get some more photo's over the next few weeks
Next job to get the fuel pump mounted and wiring alterations finished.
IS it 2019 already?
trooper1999, 4/29/2018 at 9:00 PM
The VFR fuel pump is very simply a relay with a capacitor driven off one of the ignition coils (probably a diode also). When the ign coil "fires" it energises the relay and the capacitor then holds it energised until the next coil firing.
So it *only* runs when the ign is sparking (ie turning over or running).  You can as others have said bypass it (I do this for the first start after winter etc).
trooper1999, 1/23/2018 at 10:07 PM
FYI if you are using the late RC24 engine then the RC36 output shaft is ~13mm longer and a direct swap (Unfortunately the US didn't get the later RC24 model)....You do however also need the RC36 sprocket cover and the clutch pushrod (it's longer).
Plus as a bonus all the important parts on the later RC24 *except* the gears themselves (ratios differ) and the output shaft are shared with the RC30.
Note also that the gear change shaft position also differs between the early and late RC24's (and the ign, and the valve size, and the carb size, and the ign timing...! )
Not managing to get much done this week but have a look at what a proper fuel tap looks like, this array of pipe work has been removed from the VF750 fuel tank[image: IMG_2546.thumb.JPG.1e33d8dba7714f8598cbd18875f258ab.JPG][image: IMG_2547.thumb.JPG.52489009b9b04a08efb893c1c8f6cf14.JPG]
Fastdruid, 1/29/2019 at 2:44 AM
But then you place it in the circuit again right?  Should you crash and the engine shuts down, you donot want the pump to continue pumping methink...
:beer: free flowing beer is good, petrol is not!
11 minutes ago, Dutchy
Oh absolutely, just bypass to test and prime.  I wouldn't advise anything other than a temporary bypass although if someone is determined I'd advise to bypass it by running a "normal" relay via a bank (tip-over) sensor (as fitted to EFI bikes as they will quite happily run on their side...until they run out of oil).
45 minutes ago, Fastdruid
I install a toggle switch in parallel on my bikes which allows me to prime after winter storage and get home WHEN the relay fails.
13 hours ago, Captain 80s
[image: image.png.26d18835d647f979d577dab811705a70.png]
+1 following!
This is a great thread. I’m kicking around the idea to do a similar build.
nord1, 2/15/2019 at 8:35 PM
+1 following!
That great, It's not just me that has mad ideas.
If I can be any help get in touch
Just a little update, I've been busy with all the little things alterting a bike needs, ie the oil breather catch tank, alter the steering lock to reduce the amount of travel, trying to sort the screen, making the rear engine mount etc etc all little bit that take loads of time.
I've sorted the guy who is going to paint it for me it should be with him in about a month so that's a big step, as soon as I get it back from him I'll get it apart for powder coating and then start its final build.
At the moment work and family are getting in the way but that's life.
Hi Everyone, I've not managed to get into the garage for a few weeks (family issues), I have managed to get some spanner time this bank holiday weekend, again I've been on with all the little jobs piping up the engine breather into the catch tank, making the battery securing strap and brackets. but the main item I've been on with is altering the seat unit where it joins the tank, I'm trying to make a pattern and then cutting the seat up so I can get it remade, it;s hard to cut up a new seat though. I have put off the painting until I get the seat done. ( I have to go over to the painter to collect my DT175MX tank back after being repaired).
I'm still waiting for the screen to arrive but hopefully it will be with me this week and I will get on with fitting it, while I'm waiting for the seat I might strip the bike and get the frame powder coated and then build it before it goes to paint.
I'll try and get some photos posted just to prove I not stalled with this project.
What could be better, just fitted the screen while listening to the TT practice on Manx  radio. Thought you should have a few photos.
Screen fitted but will need a little trim
[image: 20190602_152226.thumb.jpg.0e2362edc903910199a83a29e6396a14.jpg]
A photo with the seat off, you can see the rear exhaust and the new catch tank.
[image: 20190602_152319.thumb.jpg.dcf019e87d661442a553115cba7af4f1.jpg]
The last one is a riders eye view [image: 20190602_152343.thumb.jpg.6e59b3bd7717ea666b54b1c45d122f8d.jpg]
Better than sex......   :tongue:
[image: 20190711_172815.thumb.jpg.eb5c411b5e1f2613a74a23882cdc5f58.jpg]
Not much left of my project now, the frame, wheels etc are at the powder coasters, various other bits are being aqua blasted, should be collecting them all on Saturday and then start the final build.
This is SUCH a cool project!
Awesomeness
Sent from my SM-J327T1 using Tapatalk
2 hours ago, trooper1999
[image: IMG-20190913-WA0002.thumb.jpeg.05693073ba97182ba2fcab4fa8a8dbf6.jpeg]
Does that look better,  a bit more HRC?
Or do you like the VFR forks that it came back from the painters with?
Looking much more like the real deal 👍😎
The fork lowers and the top yoke have been painted
#105
I think that front end looks fantastic.
Hi All, I've just about managed to get my little replica project together and finished (well sort of finished, is a project ever finished), i thought I would post some completed photos and give a little run down of whats what.[image: 20191018_154313.thumb.jpg.2f5c74d27a83b46e6d208c156e8bc7cd.jpg][image: 20191018_154359.thumb.jpg.9e1d43e533255bc2cb00817ebd990950.jpg][image: 20191018_154409.thumb.jpg.7954b1baa945eb5e626633e1ea7f4f70.jpg][image: 20191018_154415.thumb.jpg.0e3712d739f223bef845444e5cee8cfd.jpg][image: 20191018_154429.thumb.jpg.7b37c71a91613a2f7f3422b89165bdc1.jpg]
Just a little info about the bike, Honda VF750F RC15 modified frame and swinging arm using a YSS shock, CBR600 wheels front and rear, Honda VFR750 RC24 engine with hand made exhausts, front cylinders under the bike and the rears out of the seat, VF1000R fork lowers and yokes with VTR1000F (Firestorm) uppers and internals with race springs and internal modification. Altered VF750 fuel tank, altered VFR750 wiring loom.
I need a smoke now.....😋
End of thread · 109 posts recovered Wayback Machine snapshot 6 Jul 2020
