G'day all. I am going to preface this with the fact that some details may be missed or omitted, as I'm not entirely a slouch with mechanics. I've rebuilt transmissions and transfer cases, swapped fuel and induction system components, swapped axle/steering on my truck, etc. Bikes aren't my forte per sè, but I'm not usually bad at this.
I'm in a pickle. Well, I got myself into one.
Last April, I took my VFR apart to do a PAIR delete and starter valve synch. I was in no rush, I work better when I'm not flying along, and had the bike apart a few days.
Before it went together, I was called out of town for work, and one thing lead to another, and it never went together properly. I kept everything very carefully, and am missing no parts.
This past week, I found out that for my 3rd year of trade school, I'm being sent to Moose Jaw, SK, which is 4 hours fromy home, and I will need the bike in order to travel back and forth weekly.
So, I got down to putting it together. And it all went fairly swimmingly. I replaced all of the vacuum lines under the throttle bodies, and capped off the PAUR related areas of the airbox.
When I got the bike together, I found it unable to properly idle. I had mucked with the starter valves before, and lost the factory settings, so, as a precaution, I disconnected the cold idle circuit and turned the valves fully closed individually, so as to 'start from scratch' when ready to set them. I kept the bike running until it was ~60°C indicated, and found that it would not idle anywhere near a normal amount. It takes off to 5500rpm. The wax unit is disconnected/slack, the set screw is backed off fully.
During a bit of playing around, I found that the return side of the throttle cable was not fully returning the throttle bodies to closed. If I disconnect the cables, it'll snap shut.
But when hooked up, it doesn't.
Is the return side of the throttle cable somehow adjustable in a way I'm not understanding? The throttle side is, but not the return side. Adding slack to the throttle side does nothing.
What am I missing here?
