Will need tires soon,
any thoughts on Michelin Road 5 (non GT, not available til 2019), Conti Road Attack 3 GT, Dunlop RoadSmart 3 GT and Bridgestone T31 GT.
So far i'm thinking of the Conti Road Attack 3
What have you got mounted now? Any problems and how long have they lasted?
I got the original Dunlop, bought a 2013 DCT new last summer !
I really didn’t think anything about my OE tires till I got a spike embedded and replaced them at 8K miles with a pair of Michelin Road Pilot 4s. The bike rode better everyday, confidence inspiring in the rain and with seven thousand miles, looks to last quite a while longer.
I'm ready to replace mine as well. My last set of tires I bought went on the Bking, Q3s. I really don't ride long distances, except when I picked up the VFR last fall, Chicago to Missouri and back in the same day. Very stupid. Rode the ZX14R there and did the deal and rode back. That's when I realized that the stock tires just suck. Recommendations?
I put a Q3+ on the back of mine. Just swapping the rear from my worn-out T30 made it feel like a 250 in comparison. Can't speak, yet, of the mileage, but I'm happy with the handling and grip. I haven't had it in the wet much, either, but the tread pattern looks like it'll probably give up some wet traction.
Dunlop had a $50 rebate going this month for a set. I believe Bridgestone's rebate may still be going as well. IMO, can't go wrong with either the Q3+ or T30 Evo. I was ready to get another set of T30 Evos, but a friend's high praise of the Q3 (not the "+" model) and the tinkerer in me always wanting to try something pushed me to give the Dunlops a try. It's hard to believe they're in any way related to the terrible stock rubber.
Just wore out my Angel GT's in 2600 miles. Very good tire, predictable with awesome grip. Better grip than Pilot Road 4's, but less feedback. I also got 4500 miles out of the Road 4's. Going to try the Road 5's this time. They were $50 more for a set, but if they last as long as the Pilot 4's or better as they claim, then it will be money well spent.
Still have to try the T30 EVO's, but after the slippery stock Bridgestones, I am reluctant to try another tire from them.
RC1237V Just wore out my Angel GT's in 2600 miles. Very good tire, predictable with awesome grip. Better grip than Pilot Road 4's, but less feedback. I also got 4500 miles out of the Road 4's. Going to try the Road 5's this time. They were $50 more for a set, but if they last as long as the Pilot 4's or better as they claim, then it will be money well spent.
8 hours ago, Morph3us
Yep, I put some near new BT023’s on my 6th gen which I picked up cheap off a riding buddy. On the edge of the tyre it feels like I’m riding on marbles with the back end flapping around like a gut hooked snapper. Very disconcerting. I’ll be going back to Michelin Pilots and no more from Mr Bridgestone thanks very much.
Those tires were first released in 2010 so I would be curious to know what the date code on your 023s were. Bridgestone still makes & sells them today as a budget, long-life touring tire so that tells you everything you need to know.
RC1237V, 4/14/2018 at 9:42 PMJust wore out my Angel GT's in 2600 miles. Very good tire, predictable with awesome grip. Better grip than Pilot Road 4's, but less feedback. I also got 4500 miles out of the Road 4's. Going to try the Road 5's this time. They were $50 more for a set, but if they last as long as the Pilot 4's or better as they claim, then it will be money well spent.
Did you use the GT-A spec Angel's? I believe they have the sturdier side walls for less tire flex and better wear for the heavier weight sport tourers like the VFR1200 and ZX14.
I get 4,500 miles out of my Angel GT rears of solid hard edge to edge riding... but that is the regular spec GT's on a Y2K 800... then again, with my fat a$$ our bikes probably are close to the same weight :wink:
4 hours ago, DustinThose tires were first released in 2010 so I would be curious to know what the date code on your 023s were. Bridgestone still makes & sells them today as a budget, long-life touring tire so that tells you everything you need to know.
I use BT023's on the back of my ST1100; works really well on that heavy, torquey old bus, even to the very edge. I pair it up with an Angel GT front, and the combination has not let me down once.
3 hours ago, Rush2112Did you use the GT-A spec Angel's? I believe they have the sturdier side walls for less tire flex and better wear for the heavier weight sport tourers like the VFR1200 and ZX14.
Some others have mentioned that to me as well, but I'm worried the ride will be more harsh, and I can barely muscle a regular GT on to the rim when changing tires. Some of the roads around here are horrible, while others are perfect. The 1200 is a heavy bike, and much of the weight seems to be on the front. Although I notice that when lifting the bike, so with me on board, it may be different. The other factor may be the amount of torque and power the bike has.
My 3rd gen wears out two rears for each front, but the 1200 is a 1:1 ratio every time!
I seem to prefer feedback (slightly) over grip, but am finally getting used to trusting my tires. That being said, I need all the help I can get, and good tires help a lot............
1 hour ago, RC1237VSome others have mentioned that to me as well, but I'm worried the ride will be more harsh, and I can barely muscle a regular GT on to the rim when changing tires. Some of the roads around here are horrible, while others are perfect. The 1200 is a heavy bike, and much of the weight seems to be on the front. Although I notice that when lifting the bike, so with me on board, it may be different. The other factor may be the amount of torque and power the bike has.
Correct. I asked the Pirelli USA rep that exact question years ago and he confirmed that the GT A spec would not help on a 5th or 6th gen for mileage. It would be better suited for the 1200, in much the same way that the Michelin designs their Road 4/ GT.
16 hours ago, TerryI use BT023's on the back of my ST1100; works really well on that heavy, torquey old bus, even to the very edge. I pair it up with an Angel GT front, and the combination has not let me down once.
I have used the 023s before as well and found them very competent tires. That said, the T30 was a massive step up in performance and the T30 EVO another step up again.
RC1237V, 4/16/2018 at 8:55 PMSome others have mentioned that to me as well, but I'm worried the ride will be more harsh, and I can barely muscle a regular GT on to the rim when changing tires. Some of the roads around here are horrible, while others are perfect. The 1200 is a heavy bike, and much of the weight seems to be on the front. Although I notice that when lifting the bike, so with me on board, it may be different. The other factor may be the amount of torque and power the bike has.
I get about a 2:1 ratio front to rear on my 5th gen also... I love to accelerate hard off the edges and I steer with the rear quite a bit.
You know better than I do about the torque and power of the 1200... I've only seen it leading the way through the twisty Arkansas Mtns... I couldn't carry enough speed to make it past GloryRacing on Push Mtn road when he was piloting his 1200... and he had a pillion! It's no wonder you wear out tires quick if you ride "enthusiastically".
Just remembered......I have S21's on the RC Tuono and love them, so Bridgestone is not as sour as I thought - just those stock tires (BT-016's ?) were so horrific.....
The PR5's came in today, so I will post initial impressions as soon as I wrestle them on, hopefully this weekend!
First impression of the PR5's are pretty good. Excellent feedback, and plenty of grip. Only went for one ride, and have only a few rides this season, so will push them a bit on the next ride. I do hope they last more than the 2,600 miles the Angel GT's gave me. Rear was even, but so worn I could barely see where the tread grooves were, and front was a triangle. New tires always feel better, so I will re-post after some miles........
Rush2112, 4/17/2018 at 7:45 PMYou know better than I do about the torque and power of the 1200... I've only seen it leading the way through the twisty Arkansas Mtns... I couldn't carry enough speed to make it past GloryRacing on Push Mtn road when he was piloting his 1200... and he had a pillion! It's no wonder you wear out tires quick if you ride "enthusiastically".
Push Mountain Road, aka 341! My favorite road in the central time zone! Always tried to stay in Mountain Home so the ride began and ended on that great stretch of pavement. I recall passing Gloryracing (with pillion) in opposite directions near Big Flat, two red 7th gens, what are the odds? Thanks for the memories Rush2112.
Anyway, now that I've highjacked the thread...I will be purchasing a pair of Road 5's in early May for the Ducati, will report back.
Did you do a coast to coast ride on the 7th gen?
8 minutes ago, RC1237VDid you do a coast to coast ride on the 7th gen?
Not exactly. Moved from the east coast to KCMO for work in 2008, riding the 6th gen out. Found out pretty quickly that north-central Arkansas has some great, great empty roads. Push Mtn Road on the 7th gen, a few months after purchase:
[image: Arkansas_10.10_005.jpg]
Dustin you are so right, the manufactures are ass covering,
I recall my FJR 1300 had 36psi rear one up and 42psi two up in the manual. My Honda is 42psi no mention of one or two or load nothing!
Guess what pressure's is written on the tyre, u guessed it 42.
Surely even the village idiot would understand that round black thing that your life relies on has to have pressure in it to carry the required load and also reach a temperature that allows it to grip the road as the manufacture intended!!!!!!!!!!! Well u can't put brains into statues 😳
My usual ride is 15 miles on Oahu’s crater sized pothole roadways where I doubt I see 60 mph for more than a few seconds, but have never thought but to inflate 36F/42R. Any suggestions?
andy My usual ride is 15 miles on Oahu’s crater sized pothole roadways where I doubt I see 60 mph for more than a few seconds, but have never thought but to inflate 36F/42R. Any suggestions?36/42 is the recommended pressure and is definitely not going to be an issue.
I start there and adjust based on feel, outside temperature and load. Different tires are better with different pressures for me. My current Bridgestone S21 are perfect at 34/40 but I will bump it to 36/42 for carrying a passenger. I may run a tire with a softer carcass at only 36/42, like the Avon hypersports I ran a few years ago. A rigid/hard tire like a Dunlop Roadsmart II always works best for me with 32 front, 38 rear.
Your mileage may vary!
My back ground is over dimensional and over mass vehicles, trust me tyres/tires for eg. 26000kg/57000lbs on 8 wheels were a massive cost, so load and pressures consumed my mind set because the dollars are big if you stuff up..and no wheel set ran the same pressures because the loads were not equal.
Now to reiterate, my rear for example is a 190/55x17 and on the side wall the manufacture clearly states if you are going to carry 387kg's/853lbs you must inflate to 42psi. Now in my case my motorcycle has two wheels so unless I get my 260kg/573lb bike plus my 85kg's/188lb fat person on the rear wheel only that makes 345kg's/760lb so I still have not reached the recommended load to have 42psi in the tire. So now we understand the pressure for the load, and we are always keeping in mind aren't we that the tire is also part of the suspension system for the bike because it contains air which compresses under load! Personally I like to have a comfortable ride rather than the crap flogged out of me because I have way over pressured my tires. So if one thinks 42psi (as in my case one up) is correct pressure I would say get of the drugs and seek professional help.
Now in my 190/55 it likes 33psi and hot it gets to 37psi, and here in summer if it is really stinking hot (35c/95f and more) I may need 36psi. The tire has a nice wear pattern from edge to edge so is working well. What is also helpful is the front is almost the same in pressures. Now what must be stated a friend with the same bike at 33psi always struggles to get a 4psi change because he rides more conservatively and is never able to get to the edge of the tire. Chicken strip I think its called! :-)... Cheers
4 hours ago, wevenSo if one thinks 42psi (as in my case one up) is correct pressure I would say get of the drugs and seek professional help.
But it is the standard recommended rear pressure for most bikes these days. As far as I'm concerned, 36F/42R should be where people start and then adjust based on their preferences. This is especially important when asking for advice online as this is a worldwide community with people in completely different climates, on different road surfaces, different skill levels, different sizes & shapes and different uses.
A 300 lb dude in Florida who only goes up and down the highway at 90 mph certainly shouldn't be running the same tire pressures as somebody 170 lbs carving up the Alps in autumn.
It's my opinion that the manufacturer recommended 36/42 offers a broad compromise between stability, responsiveness, handling, tire life and ride comfort for most people in most situations on most tires.
36f/42r is absolutely perfect for both me and my wife. So hey, I guess I need to lay off the drugs and seek professional help since I run 42r. My tires get good mileage and grip is fantastic, but hey, we're loonies!
It's a great starting point. Dial it in from there.
Correct Dustin, start at 42psi rear if you are carrying 387kg's/853lbs that is why the people that made the tire went to all the trouble to put it on the side wall because that is the pressure required for that load. Personally my VFR1200 never carries that load so I cannot run 42psi because it would be over inflated wouldn't it.
How ever if I had a FULL Top Box, Panniers, and a Pillion at 100kg/220lb sitting over the rear tire 42psi would be required and that is why the people that made the tire and the Motorcycle manufacture that fitted that size rim to take a 190/55 recommend 42psi because when people don't pressure the tire to its Load Rating and (I have ridden with plenty of those over the last forty years) then crash because the tire over heats and fails because it is under inflated you've got no hope re Litigation..
My only reason for my first post was to give people the benefit of my years of motor cycling experience and having worked in the tire game. A simple general rule no matter what your riding style/type is 2-4psi (for me 3-4) from cold will always work and always has done. Personally my favorite tire after many years of trail and error and trust me I have tried them all is Bridgetone starting with Bt023, S20, S20evo, S21, and now the T31 because as stated earlier I wear the front tire out to quickly, so time will tell.
I will try to attach a file from Bridgestone for tires for track day use, interesting reading. The most relevant for me is the T30 190/55 (2.2bar=32psi) and funny enough the pressure's I use for road use are only slightly higher due to higher temp's generated on a track thus more pressure rise. Hope this helps...
My S21 rear states maximum 508 lbs at 42 PSI cold. If you consider my 550 lb bike, 200 lb me with gear and 20 lbs of luggage, that's 770 lbs going down the road. If you factor a static 50/50 weight distribution, that's still 385 lbs on the rear tire without any forces acting on it. Even shifting 15% to the rear through acceleration would bring you close to the maximum.
Maybe I'm mistaken but the recommendation of 36F/42R seems very reasonable for regular, every day street use.
Dustin is your standard rear a 180/55 ZR 17 M/C (73W) TL ??
Why I ask the 73W load rating is 805lbs @ 42psi
Pleased to see your BS man, I thought the S21 were great but the heavy 1200 used the front tyre to quickly so I thought I would try a more Touring type tyre.
T31..........
Cheers
weven, 11/10/2018 at 1:17 AMMy back ground is over dimensional and over mass vehicles, trust me tyres/tires for eg. 26000kg/57000lbs on 8 wheels were a massive cost, so load and pressures consumed my mind set because the dollars are big if you stuff up..and no wheel set ran the same pressures because the loads were not equal.
Of course I run different pressures on my rear dually, sometime even left to right and of course load, but till you mentioned it, I’ve never thought about my bike tires. I’ll try your 37psi as a baseline. Mahalo.
Andy start at 37 ride 15 miles or there about preferably some nice bend carving and work the tyre then look for a 3-4psi increase.
As an example temp here Saturday about 27c started at 32psi rear, rode 20k's on a twisty rough road, checked, my increase was 3.5 psi continued for another 120k's checked again at home was 4psi, I'm happy with that. Cheers.............. 😎 Be mindful different brand's different pressure change, mine Bridgestone T31.
Interesting to me that my Multistrada sets 42 rear as a maximum in the owner's manual, giving a range based on weight. First time I've seen this.
[image: fullsizeoutput_10ce.jpeg]
