Part of Phase 3 of my eVo4 project was to try and eliminate the throttle cables. I realise there will be some who have no problem with throttle cables and can't see any point to my efforts, but I don't care. As far as I'm concerned they get in the way, their adjustment varies as you turn the bars and they have no place on a bike that is in fact Ride By Wire. Honda are not the only manufacturer to have done this as the Aprilia Tuono (at least the later ones) are RBW but until very recently also still have cables.
Why Honda decided to use cables I have no firm idea. The most likely reason was suggested to me by a dealer who thought Honda were just being mindful of the conservative nature of motorcyclists and only gradually introducing the concept of RBW and missing throttle cables. So first we get just RBW with cables, then later drop the cables. This is certainly typical of Honda thinking, but as we know, they never changed the VFR1200 in this regard (or any other in fact) and other manufacturers introduced RBW with twist-grip sensors and no one seemed to have a problem with those. Anyway...
I don't like the cables and wanted to replace that system with an integrated twist-grip sensor. I studied the BMW and then the KTM systems, but their output didn't match what the VFR's ECU was expecting so some sort of converter would be required and I felt that was a step too far as I figured eventually, there'd be a Honda part that would do the job.
First came the RCV thingy, but any parts for that would undoubtedly be a stratospheric price (even more than normal). Eventually in 2017 we got the new FireBlade and checking its Service Manual revealed that despite its different sensor type, the output was in the same range as the VFR's. So although the VFR's TCP Sensor (cable driven, mounted on side of throttle bodies) is a simple variable resistor and the new CBR's twist-grip is a Hall Effect position sensor, they both do the same job. Two independent sensors (for reliability and error checking), a supply voltage and ground connection and the output signal which operates in the same voltage range on both bikes. Not totally surprising really as Honda's designers would be working to the same parameters and the same output voltage ranges would make sense. So...
As soon as the new parts became available in 2017, I took a chance and ordered a new 2017 CBR1000RR FireBlade twist-grip and also the LH switch so they would match and I could use the additional buttons for the Cruise Control. Once received I set to modifying things as necessary. This was relatively easy for the twist-grip. There are 6 wires - power, ground and signal for each of the 2 sensors so it just required matching them up between the new twist-grip and the VFR's loom. The LH switch was much more complicated, but not relevant to this thread.
Unfortunately, health issues brought this project to a halt last year and I only got it completed a few weeks ago. However, I can report that it works. Perfectly. YAY!
I've just returned from an approx. 1000 mile trip without a throttle cable in sight (well, not on my bike 😀) and nary a hiccup. By which I mean that the throttle control has been perfect. I could say that you couldn't tell the difference from a std. VFR1200, but that would diminish the pleasure I get from not seeing those cables flapping about. Truth is there is NOTHING negative I can report about this. The throttle operation is smooth and very direct and of course never varies as you turn the bars etc. Just perfect all the time. I also really like the single combined Kill switch and Start button and the aforementioned buttons on the LHS which are perfect for my needs, although I still added some additional very neat buttons by Motone on the RHS for the handlebar heaters and on the LHS for Cruise Control memory functions.
So, anyone who like me would like to dispense with the throttle cables on their VFR1200, a 2017 FireBlade's twist-grip can be used to do so. I expect the latest Africa Twin twist-grip could also be used, but I've not looked into that.
I do love it when a plan comes together 😁
[image: eVo4-v3 - 9.jpg]
