[image: imageproxy.php?img=&key=2f13eb558190e64dcf425edcc36f26045780][image: imageproxy.php?img=&key=2f13eb558190e64dcf425edcc36f26045780][image: imageproxy.php?img=&key=2f13eb558190e64dcf425edcc36f26045780][image: imageproxy.php?img=&key=2f13eb558190e64dcf425edcc36f26045780]Hello guys,
I'm in big searching for the Key code...
Bike was stolen in Australia, I've buy him on Ebay,... Papers are (we already discussed this...)
I have to find a Key Code, to make a new key... Cause, original key I don't have... I don't know how to find a first owner to please him,or something...
I opened the seat lock, I've found on him some numbers/simbols...
So if someone know if this symbols on next pictures can help something... It would be great...
Don't know too much about it so... Thanks for understanding
[image: IMG-20180831-WA0003.jpeg]
[image: IMG-20180831-WA0001.jpeg]
[image: DSC_0056.JPG]
I assume as it came from Australia it will have the HISS security system? If so you need to do more than just cut a new key. Do you have any key at all that starts the bike or the original HISS code? If not you will have to purchase a used ECU and the key associated with that ECU to get the bike to run. You can get these off eBay with all of the locks from crashed VFRs. I think there is someone on eBay that can cut a key and program the HISS key if you send them the ECU. Good luck.
You need the key number. Mine has 3 numbers. A locksmith may be able to cut a key if you take him the lock tumbler. New keys will need to be coded.
Contact Honda they may be able to help.
Marooncobra
Thanks for helping,
I've found a guy (one member on this forum suggested me this guy), I can paste the link if someone needs..
I know that I have to make more than just key cutting...
But we can't open the Gas Tank, I don't have ignition cylinder to make a Copy, and I don't know where I can find a key code...
fink, 9/6/2018 at 10:46 AM
Sir,
Please if you can check anyhow, if the key code is hidden on rear seat lock cylinder?... I know I searching a lot,, but if you can anyhow help.... No another way to find out.. I don't know another way to get informations
Thanks mate
Tumbler is important before cutting any key , i also have given woodstock locksmith tumbler to make the new key.
All thoughts have been really helpful to do the replacement of the lock tumbler , thanks all you have bucks from hiring locksmith richardson tx.
Tnx guys
I've already make problem done... Pretty cheap,
Guy from Poland 🇵🇱 programed two keys (without Original one), and everything is fine
200€ cca with new ignition cylinder from some other Honda...
Key code is essential if you want to make a new one , you can ask both dealer and locksmith to make you new duplicate key if you have the key code.
But key code is not only useful if you don't hire any locksmith to program it like i've used altrincham locksmith for key cut and program.
InterceptoRRC79, 9/12/2018 at 2:20 AM
Sir,
Thanks mate
Locksmith can find that code easily you won't have to think about it a lot.
