After fitting a modified NC30 lower radiator a couple of years ago, with Gen 8 second hand parts become available, I thought I'd do the entire "Front Radiator" thing and ditch the side rads.
Basically got hold of an upper and lower radiator off eBay and bought the rest of the hardware, brackets, hoses etc. from Partzilla from the Gen 8 parts list.
I had to make the top bracket, up against the head stock and as the fan on the Gen 8 is controlled from the ECU, I had to put a thermo switch in the new top hose.
Since completing the job, it has run extremely well with me only seeing a top temp of 98 dec C and this is during our summer in New Zealand.
Here are some photos of the finished job.
[image: 20190128_133203.jpg]
[image: 20190128_133207.jpg]
Thermo switch
[image: 20190128_133223.jpg]
[image: 20190128_133233.jpg]
Top rad with guard
[image: 20190128_133252.jpg]
[image: 20190128_133306.jpg]
Had to shorten the bottom bracket by 15mm to fit within the Gen 6 fairing
[image: 20190128_133404.jpg]
Modded Gen 8 radiator guard on the bottom
[image: 20190129_065653.jpg]
Fashioned some expanded aluminium sheet to fill the fairing ports where the side rads were.
[image: 20190129_065710.jpg]
Had to fit a relay to run the fan off the thermo switch as it's current rating was a little low.
