The left bar is now straight, I extracted the stuck fr brake master cyl cap screw, and it is getting "new" switch gear to get rid of the shitty early switch assemblies.
[image: full?d=1549783787]
RC51 throttle housing and a CBR1000RR starter switch. The RC51 starter switch has the correct plug, but the lead is too short to make it to it's location on the wire harness side.
So, original lead made to be connected the the "new" RR switch. These lengths put the mid connectors right behind the right frame cover for easy replacement if needed.
The "new" fairings had some damage around the mirror holes, so I made up some covers to hide and encapsulate the damage.
[image: full?d=1550589969]
Held in place with some thin, high strength double backed foam. There's an o-ring under the cap to put a little pressure when the mirrors are installed.
Nice work. Good to know about the RR starter switch, I'll keep that filed away for the future.
And like I said, the RC51 has the correct plug if you are missing everything. Just need to lengthen the leads and relocate the terminals withing the plug the match the wire harness side.
1994 CBR1000F fork tubes in 1991 VFR lowers with upgraded springs. 3.5x17 CBR1000F wheel and will get 1991 VFR brake calipers. Setting up new lathe at work to machine a hub and some spacers to fit the 5.5x17 VTR1000F rear wheel. Oh yeah!
What connectors are you using? I like those much better than stuff I've found locally. Do they come with the clear shield, or are you cutting tubing?
Any crimping tool you'd recommend? I usually solder most of my connections, but for some OEM ones that just need a new fitting it makes more sense to crimp on a connector that fits.
[image: 34-9109_L.jpg]
Rolls and crimps those style connectors perfectly.
Rebuilt brakes are assembled. Trimmed the rear turn signal mounts and reshaped the fender.
Cockpit is looking pretty good. Switched to a CBR1000F master cyl so the double banjo bolt on the individual lines could clear the dash. I have a CBR1000 clutch master on the way so they will match.
[image: full?d=1560051025]
Need to solder in the reg/rect and install a fuel cut relay switch and a fan switch. I removed the casting for the side stand rubber so my boot can fit under the shift pedal easier too. I also installed a 1000F left engine mount since I'm not using the stock shock (where the damping cable and air hose normally mount).
I still need to give everything a fine cut / polish and do a bunch of touch up. The white fender is very hard to get used to, but after spinning around for just one evening it already seems OK. [image: [IMG]]
The wide wheels and radials, new suspension and brakes feel amazing. [image: [IMG]]
