Electrical gremlin identification
6 posts Started 17 Mar 2019 Last recovered post 24 Mar 2019 Wayback Machine snapshot 26 Feb 2020
Hi guys,
My VFR has been perfect so far but today it left me stranded for the first time.
Situation:
I have the VFRness installed. 13.4V at idle is my charging current.
I have done about 150kms after winter break. (trouble free). Today I washed the VFR and  some symptoms appeared.
1) When I turned the blinker on speedo and tach died for a second (dead while the bulb of blinker was on for the first time)
2) Speedo and tach dead when I turned the blinker on every time the bulb turned on.
3) Speedo and tach dead every time I pressed brakes.
- I stopped at the side of the road.  VFR refused to start again. Pump primed but starter didn't move after the button press. After I pressed the starter button pump primed again as if I turned the ignition on and off.
4) My friend came to rescue me with a new battery. (12V-12Ah insted of 12V-10ah) bike started right away and finished the 12 km journey home without issues (lights were off).
When I came home I tried blinkers again, no issues.
New battery had 12,4 V (engine off), 13,1V at 1500 rpm
The old battery had 11.6V and is now charging.
My questions are:
Why? What happened?
Is there an issue with Reg/Rec? (it is charging now so how can that be?)
Could it be water from the washing?
Follow below and report numbers.
Thank you, I completely forgot about "the Drill" article.
Did the drill, it pointed towards Rec/Reg. I have consulted this with my mechanic who seconded the thought. I have just installed the new one and will measure the current after the VFR cools down again.
However I think the problem is solved.
Here are the promised numbers
Battery :12,91V (new)
Idle: 14.36V
Slow idle with lights: 13.2-13.3V (12.8V at 80° engine temp... All other readings same at 80°C engine temp)
3.5k revs without lights: 14,43V
3k revs with lights :14.38V
battery after test: 12.99V
reg unit is Tourmax
12 hours ago, SportTouringCZ
Idle: 14.36V
reg unit is Tourmax
Looks like you nailed it down. - - I am unfamiliar with the R/R brand, but it would be wise to add a voltmeter up front to keep an eye on system health.
That is definitely going to happen, VFRness is in, meter is next.
FYI: Tourmax are Japanese made spares. I have used their steering head bearings and fork seal kits and I like them. Hopefully the quality of Rec/Reg will match.
Thanks for help.
End of thread · 6 posts recovered Wayback Machine snapshot 26 Feb 2020
