12v Power Outlet Bracket
13 posts Started 12 Jun 2019 Last recovered post 9 Jul 2019 Wayback Machine snapshot 22 Aug 2019
Hey 5th gen owners!
I have been working on a 12v power outlet bracket for the 6th gen
 and it appears that it may actually fit the 5th gen as well. Is there anyone in the GTA, close to Newmarket with a 5th gen who would be interested in a bracket and testing it on their bike for fitment?
Take a look at my write up below
Let me know what you all think, Cheers!!!
I like it a lot! However, you loose half the 5th Gen market because the '98-'99 don't have the plastic bezel. I fall into that category with a '99, but I front end swapped mine and now have a 954(?) top triple that should have a plastic bezel. I have been wondering for years how to clean up the space where the bezel would sit. Considered installing a stock bezel, but the key position marking are on the barrel of the switch already. This looks like it would cover the recess in the triple and delete the empty screw holes. Also give me a nice power socket placement and maybe figure a way to get my volt meter installed again. Previously it was installed in the plastic, and after a rebuild with custom painted side fairings I couldn't bear to cut into them.
I wonder if the angle on the triple is similar enough to fit it?
[image: 58EEAB99-37F9-4E6E-A173-9000F7E8A391.jpeg]
[image: D6D1F0EC-64FB-430D-BE51-67BA89836728.jpeg]
What do you think from the pics? Will it work?
9 minutes ago, BuzznerSuntrusts
I hadn't realized that they changed the upper triple tree on the 5th gen part way through. That's good to know!
10 minutes ago, BuzznerSuntrusts
The angle on the 954 triple clamp seems to be a lot less shallow that the stock triple. If you'd like I can PM you a PDF stencil of the outline of the bracket and you can do a dry paper cut out fit to see.
Let me know if you'd be interested!
Just now, TriumphTraitor
Yeah, do that! Thanks, that'll be great!
Looks good!
[image: C9ADFA1E-10C4-46E9-8F36-FE176BFD57F3.jpeg]
Looks like it fits pretty well. Does it clear the gauge cluster when you turn the bars?
36 minutes ago, TriumphTraitor
Yes.
Those were the only bolts I could find that would fit. I'll have to source some interesting matching ones.
Ebay has a fantastically selection of stainless cap screws, I got a 10 pack of m6 stainless steel  torx cap screws for like 3 bucks.
Well if you're interested, I can get a quote on shipping for you to ship the bracket
Let me know!
I'm so glad you met VFRpower! If he's who I think he is he is an awesome VFRD'er!
He's a pretty solid guy that's for sure! I was amazed he lives legit like 5 mins from me... Small world
Sent from my XT1635-02 using Tapatalk
Working on getting the rear brake swapped out. I’ll be looking for something to fill the holes shortly.
[image: 9255B01B-0355-4A5F-AE0E-A20A0A976864.jpeg]
This is cool, man!😎
TriumphTraitor recommended a set of charger and voltmeter on eBay, but I found the same one on Amazon for a couple bucks more. The catch is that it already rode the slow boat from China so it got to me in a weekend instead of like 3 weeks.
Wired up and ready to rock-n-roll:
[image: D334C568-84D8-4905-8CE5-96869789F339.jpeg]
1 hour ago, BuzznerSuntrusts
This is cool, man!😎
Looks really good, mate!
Glad to see it fits. I'll have to keep Amazon in mind for these next time
End of thread · 13 posts recovered Wayback Machine snapshot 22 Aug 2019
