Not sure if you're trying to source a stock FPR or uprated for some reason? If the latter, are you just looking for one which will work in that range? I don't know much about these things, but just came across this while looking for something else...
I'm after a 4bar version that will bolt in to the stock location. I just tried a local motor factors & its not just me they do not appear to be available in the UK.
Out of curiosity, when do you need a higher pressure regulator? Presumably you’ve made other changes to the bike?
Good luck anyway. Hope you find one.
Stuart
Yes I have fitted some modified throttle bodies & CBR929 4 hole injectors. Bike was showing lack of fuel via Rapid Bike MTB O2 sensor. So a check of the CBR929 manual shows it uses 51psi at idle. The VFR is only 36psi static. Pushing a VFR regulator to max pressure only realises 44psi static, still to low.
The low pressure reduces fuel atomisation so the injection is not duty cycle efficient. The Rapid Bike has compensated with additional duty cycle percentage.
Why don't you adjust the preload on the spring on your OEM?
I tried with a spare VFR one, it bottoms out at 45psi, so won’t open then at all, I’ve taken that bottomed out one to 70psi with no pressure relief. I then cut it open & the springs fitted to these are just a couple of mm’s short of maximum compression to ensure a consistent pressure & minimum lift when vacuum is applied.
OK so I’m going to try plan B. I have an adjustable FPR that is to big to fit in place, so I’ll replace the stock one with a hose adaptor & add an extension to the fuel return hose via the new adjustable FPR !
Looking at the spare set of fuel rails They weigh a ton. So some trimming there will offset the additional weight of the AFPR.
Not to derail your plan, but is there room to install one of these on a stock fpr? They're all over ebay for the cars, but it's basically the same style regulator. It looks like it might fit...
I ran across this because my MPG has been plummeting and I suspected my FPR... it didn't leak any fuel, but I think I found the offending damaged vacuum hose.
I did order 3 of those, but all 3 were not delivered & cancelled by the sellers !
So after much searching I came across this small unit. "Saxon M/spt Silver CNC Machine Housing for Bosch Fuel Pressure Regulator Jenvey" on the bay. So with a few AN-6 adaptors & converters I was able to do this.
All sealed & adjusted & now 4bar pressure to suit the CBR929 4-hole injectors requirements. I've set the RBR to a zero fuel map & will do some miles & see how it adjusts.
