2002-06 (6th gen) VFR 800 engine with VTEC with engine stand. Good engine to hone your VTEC valve adjusting skills on, getting experience removing the cams to lock the VTEC buckets, then put it all back together so you can take the required shim measurements without worry about messing up the engine on your bike. Engine comes with the stand and engine mount. Tilts and locks at 0 and 45 degrees for easy access. Engine stand is like new condition, rated to 1500lbs, can be adapted to hold other engines.
$250 with engine stand. Buyers pays for shipping.
[image: IMG_1797.JPG]
[image: IMG_1798.JPG]
[image: IMG_1800.JPG]
[image: IMG_1801.JPG]
