richieg, 4/23/2020 at 11:08 AM
Looking at ditching the combined brakes on my 2003 and I like the look and simplicity of the 8th setup. Anyone know if 8th Gen forks or even just the fork lowers will work on a 6th gen?
Would like to retain the 6th front wheel and brake rotors for the time being (to keep cost and barriers to this going ahead) so hoping it will still fit with 8th gen forks and front brakes. Anyone know for sure? What about mudguard???
Also, the 8th Gen forks look like this hey have more adjustability... Are they much of an upgrade of 6th gen?
I'm hoping the 6th master cylinder will work with the 8rh radial brakes. Anyone know for sure?
Rear brake wise, I'm thinking of either only using outer pistons or using a different size master cylinder. Is there much of a difference performance wise?
Sent from my ONEPLUS A6003 using Tapatalk
You can mount 8gen fork lowers directly to your 2003 fork tubes, Honda kept the upper tube length, diameter, and spacing of the triples identical between 6th and 8th gen. The problem you're going to run into trying to retain the wheel and discs is that the 6th gen has 296mm discs that mount with 6 bolts, and the 8th gen has 310mm discs that mount with 5 bolts. So using the 6th gen wheel and discs, the brake pad won't actually make full contact with the disc. And trying to use larger diameter 8 gen discs won't bolt to a 6 gen wheel to try and retain the wheel. Best option is finding a used front end from a salvaged 8 gen on eBay.
And if you're referring to the front fender when you say mudguard, Honda reused the front fender from a 2016 cbr1000rr on the 8th gen vfr, so you can find any number of those from oem to after market carbon fiber on fleabay.
Adjustability on 8th gen forks are no different from the 6th gen IF you find the 8 gen standard forks. If you find the 8 gen deluxe forks then you do get extra adjustability. For compression I believe.
You should be able to reuse your 6th gen master cylinder but I'm not 100% on that because I'm using nissin radial master cylinders.
For the rear brake, I swapped an entire 8 gen swing arm onto mine, which are already delinked as you know, so I just had a single custom brake line made that I ran to an 8th gen rear master cylinder.
Best of luck.
