Does this look like it's missing any pieces underneath? I see the rubber stops, etc, and though my hand is covering the right side somewhat, it is the same as the left. The rear most part of the seat cowl doesn't sit staticly. I can press down and the plastic makes hard contact with its mount like it's missing a rubber piece of some kind so while I'm hitting bumps in the road, it's making minimal, but hard contact. Best I can tell, everything is there per parts breakdown diagram. I might need to craft a cushion of sorts.
Hi, New to the forum. When I pulled the tail off my recently purchased VFR I noticed some velcro on the two rear bumpers. I figured the PO must have had an issue with it vibrating.
Hi Goldcrown 44, I just checked my seat cowl and looks exactly the same as yours, no extra rubber mounts ect. I can press down on mine and there is no hard contact. Maybe check the locking mechanism isn’t a little loose and that the mount for the locking mechanism on the underside of the seat is also tight. Good luck.
Viffer Hi, New to the forum. When I pulled the tail off my recently purchased VFR I noticed some velcro on the two rear bumpers. I figured the PO must have had an issue with it vibrating.
Any chance you can post a pic of the previous owners mod?
Here are some pics. The PO attached Velcro to the 2 rear bumpers. I also noticed that he added two small strips of thin rubber where the 2 front bumpers come to rest on the bike. Still waiting to see if he can find the tool kit.
I just did the velcro thing to the aft round rubber stops, and added a layer of cushion to where the fore rubber stops make contact and it works great... no more cowl rattling.
Can't say I've noticed mine rattling but your picture of the cowl underside above has made me realise I've lost the front two rubber things (no.6 on the parts diagram)!
End of thread · 9 posts recoveredWayback Machine snapshot 13 Jun 2021
