Gear lever position
4 posts Started 30 Jul 2020 Last recovered post 30 Jul 2020 Wayback Machine snapshot 13 Jun 2021
Hi all !
Two weeks ago I've installed OEM quickshifter in my 2014 VFR. Unfortunately yesterday was the track day and I lost part of it, this pedal covered in gum.
I have to return back to regular lever...
Does anyone can share with me photos how it is installed on your bikes. On rod coming from the engine there is a little dot so it will be good if that part will be visible.
Thank you all.
Hi mate.
Not too sure what you are requesting, but here is a picture of the normal gear shift lever in the standard position. As you can see the gear shaft dot is in line with the gear shift lever slot.
Is this the information you wanted?
[image: image.jpeg]
@Grum exactly that is the information 🙂 thank you very much 🙂
2 minutes ago, mate
Nie ma za co! :beer:
End of thread · 4 posts recovered Wayback Machine snapshot 13 Jun 2021
