5 hours ago, lazyeye
This is a hypothetical, just something I've been kicking around in my head for a while and now that I'm not riding all the time...
Hypothetically if someone wanted to modify a 6th/8th gen bike to be "always" in VTEC (always running on 4 valves per cylinder), how would you do it?
The best way to get rid of the rough VTEC transition is to always run in VTEC!
When I checked my VTEC's valves, I more or less realized that is what one is doing during the clearance check procedure. There used to be a good online guide to it, but it's now a dead link. The attached youtube video, despite the annoying music which is too loud over the narration, is a decent "how to" for a VTEC valve check. The reason the cams have to come out and go back in 3x is that the 8 VTEC valves must be set to work at all times to check their clearance. That is done by removing the VTEC buckets and the internal latching mechanism and pinning it closed with a shim, then replacing the bucket/latch assembly back over the valve. During non-VTEC operation, the latch is open and the valve stem rides up through the open latch inside the bucket, leaving the valve closed. When the spool valve closes, oil pressure is diverted in to a spider web of 8 passages to the VTEC valve lifter bores, pushing the latches closed so that when the bucket comes down (it goes up and down using a lighter, secondary spring regardless of VTEC engagement) the latch contacts the valve stem pushing it open. Theoretically it would be possible to place the shims in that manually latch the VTEC latch mechanisms close and leave them in - thus forcing all 8 valves open all the time. This came up in another post a while back and I think it was pointed out that latching the valves closed that way could cause some oil pressure issues if the oil has no where to go. The more I thought about it, it seems as though that once the latch closes by pressure the oil doesn't have anywhere to go, anyway. It just drains out the bottom of the VTEC bucket. Besides, the passageways are very small (a good reason to keep oil clean on a VTEC btw) and wouldn't seem to make up much of the circulating oil's volume. I may be FOS on all that, so if someone knows definitively, chime in. The other downside is that more reciprocating mass is added to the VTEC portion of the valve train. The shims are about 6mm in diameter and only about 1/8 inch to maybe 3/16ths in thick, so they're very small. Hard telling if there would be any long term effects to this. So to do this, in the valve procedure, it would be 1. Remove the cams 2. Install the shims on the 8 VTEC valve latches 3. Replace the cams. 4. Check all 16 valves - adjust as needed (by removing cams) 5. Replace cams and ride. There are numerous unknowns in all this - but theoretically it's possible.
https://www.youtube.com/watch?v=XEimE9DptP4
The other way would be to install a 2nd VTEC solenoid, grounded and connected to the ECU through the normal connector. The ECU wants to see that before it will fire the engine so it must be in place. This is only to fool the ECU in to thinking that it's actually actuating the VTEC valves. Then, set up a switched 12v source (or maybe 5v? - you'd need to check for that) to the installed VTEC solenoid in the "V" and allow the switched power to open the solenoid and keep the VTEC passageways pressurized at all times. That would be a simpler approach - so either mechanically or electrically. You would need to remove the throttle bodies to get at the spool valve connector. I don't know of anyone who's ever done either in practice (for full disclosure I did not) but either seems plausible. Going the spool valve route would be the most easily reversed if it turned out undesirably.
Regardless, it would seem there are going to be some tuning issues to be sorted as the airflow below 6,400/6,800 rpm will be changed. That could either be a dyno session with a P.C., or letting a Rapid Bike do it automatically while you ride. The latter is slick - plugs in just like a P.C. but is way more capable. It uses the 2 stock O2 sensors on a VTEC and changes parameters on the fly to a target AFR while the P.C. only uses a set tune and does not change. Autotune is available for P.C., but is a manual process vs the automatic one with RB. Out of the box the RB tune is outstanding for a VTEC and just gets better as you ride it - I've been very pleased with it.
If you do this, please do a write up - AFAIK you would be the first to do so and post it publicly.
As always, YMMV
