I need to take the front wheel out on my '03 VFR800, and I'm wondering which type of front stand is best for this, assuming it makes any difference.
My local shop has both types, with the pin and forked versions, but is either one better suited here? I noticed there's space on the bottom of fork legs, so I would suspect the pin type.
I go right to the triple tree stand. Then I can pull the wheel/forks if I need to. Front stand that lifts from the forks/calipers aren't great if you need to work on something.
I've never had a front stand. When I've needed to remove the front wheel I put the bike on its center stand and lift the front end of the bike with a floor jack, putting a small piece of 2x4 between the jack's "saddle" (the pedestal or pad) and the header pipes. I'll be buying at least one track/paddock stand soon though, so I'm interested in seeing others' responses. 🙂
