Measuring pickup resistance?
12 posts Started 27 Nov 2020 Last recovered post 6 Jan 2021 Wayback Machine snapshot 23 Jul 2021
Hello fellow riders,
I've been trying to months to resolve issue with no power in high rpm on my RC36 VFR 750 1990. Issue is not related to carbs and whole air/fuel system, since all that was serviced. It seems that is electrical problem. I found out that one spark plug cap was giving 1000+ kOms, so I replaced that. Also I've been measuring all electrical installations, and found that I don't get good measuring on pickup. According to instruction, when I measure resistance on 4P mini connector between yellow and white/yellow I should get between 200 - 400 Oms, but when I measure resistance between yellow and white/blue I don't get nothing. Also, when I measure on the ICM side resistance between yellow - white/yellow and yellow - white/blue manual says that I should get 450 - 500 Oms, but I get around 290 Oms.
So to recap:
ICM side measurement:
Yellow - White/Yellow 290 (450-500 according to manual)
Yellow - White/Blue 290 (450-500 according to manual)
4p mini black connector
Yellow - White/Yellow 290 (200-400 according to manual)
Yellow - White/Blue 0 (450-500 according to manual)
I'm wondering if I'm measuring resistance on right way. Can anyone explain me how to properly do that?
Thank you in advance!
Daniel
Hi Daniel.
The procedure for checking the Ignition Pulse Generators in the manual has a typo error.
Its states to measure between the Yellow and the White/Blue this is incorrect.
Should be Blue to White/Blue. 200 to 400 ohms.
And the other is the Yellow to White/Yellow. Again 200 to 400 ohms.
Refer to drawing attached.
Hope this helps
Cheers.
Hi Grum!
Thank you for this note! I will measure tomorrow, to see will it be any difference.
6 hours ago, Peka
Don't rule out carbs just because you had them "serviced". It really depends upon quality of work and skill by person doing them. Requires lots of scrubbing, ultrasonic soaking and micro soda-blasting.
When I got my Ninja 250 race-bike from retiring AFM-racer, I figured I'd send to dealer for "servicing" of carbs. Nothing... Then 3-days later, I get call from service-tech asking where they can find OBD port to connect diagnostic scanner!!  Hahahhahaha!! I ended up sending them to Gordon (ducatiman) in NY for restoration as he's only one I've found that can do expert job on carbs.
Also did you rebuild petcock?
Measure its opening vacuum and flow-volume?
Grum, 11/27/2020 at 10:31 PM
I measured according to this, and it is fine. But when I measure on back side, on ICM side, it is also around 290 oms, instead 450 - 550 oms, according to manual.
[image: image.thumb.png.a82cf202e062d28757f7c8d1a0a312cf.png]
Should that concerning?
DannoXYZ, 11/28/2020 at 2:49 AM
Thank you for this suggestion, can I ask how to do this?
3 hours ago, Peka
Are you measuring this with 4p plug still connected to the Pulse Gen Coils? This would explain your reading of 290 ohms.
From what I read, the coils need to be unplugged for this test, you are measuring the resistance of wires Yellow (common) to White/Yellow and Yellow (common) to White/Blue.
This is a measurement of the ICM internal resistance to these wires and you should have between 450 - 550 ohms for the two readings.
You have already confirmed both the Ignition Pulse Coil resistances are correct, and with the coils still connected it would be impossible to read 450 - 550 ohms in the above test unless they were unplugged to then measure resistance on the wires back to the ICM.
Hope this helps, also I don't have a 4gen. Just going by the circuit diagram and the test procedures!
Good luck. :wacko:
[image: IMG_0964.PNG]
Grum, 12/2/2020 at 10:25 AM
Good luck. :wacko:
I tried to measure on ICM side. So I unplugged coils, and unplugged 4p pulse gen connector. Measured on ICM side, but I didn't get any results. Do I need to turn key ignition on ON (II) position while I measure? Or crank the engine? Since I don't get any readings when I measure? Either ICM is broke 😄
Ok then perhaps the stated reading of 450 - 550 ohms. Is also a typo error and this test is just confirming the wiring and coil resistances from the ICM connection down to the coils!!
Sorry i can't offer more info as I have never owned or worked on a 4th gen.
Perhaps any of the 4gen owner members might be able to clarify this for you.
8 hours ago, Peka
if you unplug the connector to pickup-coils you can't measure them.
The idea is to unplug everything except what you want to measure. And you're measuring terminals at the ICM connector right? Not the ICM itself.
Note from diagram, that wire-colours change for pickup coil after connector. Best to do 2-readings, one at pickup-coils themselves and one at ICM connector to verify wiring in between.
Better test is to use oscilloscope to test output of pulse triggers at ICM connector. Do you have access to oscilloscope?
Hello guys!
Just to let you know that I fixed the problem! ICM and one sparkplug cap is replaced, and now bike is like new again!
Thanks for the help!
Good job!
Seems ICM failure is more prevalent than I would expect.
Honda must have used same electronics department that was responsible for RR debacle.
End of thread · 12 posts recovered Wayback Machine snapshot 23 Jul 2021
