cold exhaust on cylinder 3 gas 50/50 mix oil and gas
11 posts Started 11 Dec 2020 Last recovered post 5 Jan 2021 Wayback Machine snapshot 23 Jul 2021
anyone have any ideas why cylinder number 3  would be cold  and oil is at least half gas  . and i am getting good spark on all plugs, and do you think having my fuel injectors sent out to be checked will help ?
How did you verify you have spark on that  cylinder?  I wouldn't rule out an injector issue but the fact that it's cold points to the fuel not being ignited. I would dig deeper there 1st before chasing the injectors.
You can test injectors yourself to see if they're leaking.
55 minutes ago, DannoXYZ
i have tested them to see if they squirt  and they seem to work fine  i dont know how to test them for leaking
1 hour ago, Cogswell
pulled the plug out and turned over engine . pulled the injectors out and tested them they seem to work . now i think im going to test a pressure regulator
A ruptured diaphragm in the FPR will cause fuel to be sucked into cylinders 3 & 4 via vacuum hoses.
The odd piece of the puzzle is why #3 is cold.  How could the plug be functioning and leaving the cylinder cold?   Maybe the plug has a cracked insulator?  Or maybe a deteriorated HT lead . . . ?  Or the spark is weak and appears to be working visually but doesn't deliver enough energy to ignite the fuel air mix under pressure.  Maybe I should ask - how cold is cold - cold as in "can grab the header tube cold", or just "not as hot as the others" . . . Any additional color on that?
Very low or nil compression would do it. Curious to learn if this ever is solved/resolved...
6 hours ago, Cogswell
3 hours ago, airwalk
If it is a ruptured FPR Cylinder 3 won't fire because of the excessively rich mixture of raw fuel drawn in. Another effect of this can be the smell of raw fuel from the exhaust.
A similar example is to start your bike from cold and have it run for just a few seconds. Turn off and come back the next day and try and start your bike, there is a very good chance it won't fire up or extremely reluctant to, a flooded over rich mixture is now in the cylinder. This has caused a lot of heartache for a vfr1200 owner,
and I've experienced the similar effect on my 8gen.
It's the reason why you have a "Flooded engine start procedure" in your owners manual. The cylinders need to go through a purge process to get back to an ignitable air/fuel mixture.
Another scenario. A few years back I had my 2013 Mazda 3 cold in the driveway, washed the car, started it up and drove it 25ft into the garged and switched off. The next morning I dam near flattened the battery trying to start it. I had to follow the flooded engine start procedure before it finally spluttered into life. A very common known issue with that generation of Mazda 3. The simple fix is to always run the engine long enough to be slightly warmed.
7 hours ago, Grum
 Cold as not even warm  to the touch,  I just purchased a fuel pressure regulator on line at Partzilla but it will be a week or so until i get to putting it on. I will let you know if this fixes my problem when i get .
Just to update. This thread seems to have crossed over to this one.
Fix was a new Fuel Pressure Regulator.
End of thread · 11 posts recovered Wayback Machine snapshot 23 Jul 2021
