Walker1, 3/11/2021 at 6:25 PM
Thanks guys.
Ok, the most complicated part of this job seems to be sourcing all of the parts.
The forks may need a servicing and they may also need fresh springs to suit my weight. From what I understand is the stock springs are suited to a 155lb rider. I’m around 180 without gear.
I’ve spoken to a specialist here in Ireland and have done some calculations in regards to the title of this thread.
Firstly, if I were to go with DMR in America and have it shipped it would cost 800 euro for the shock and 600 for the forks which would still need servicing (new seals, oil etc) totalling 1400 euros plus service (not sure of the cost)
The specialists recommended a wilbers (640 i believe) rear shock for 580 euros and wilbers progressive springs for the front for 160 euros. Totalling 740 euros plus service (not sure of the cost) which i may be able to get them to do if I also get them to fit the shocks.
What I was thinking is; ordering DMR rear shock =800 euros and wilbers progressive springs for the front =160 euros plus the price of service and fitting =960+??
What are you’re thoughts and opinions on this.
Would the difference between wilbers rear shock and DMR rear shock be worth the 240 euros extra?
Fellow Irishman here (well, Corkonian).
Have you taken a look at YSS shocks and springs? They get good reviews and aren't bad, price-wise. They're rebuildable too.
On my VFR 750, I replaced the factory forks springs with springs from Progressive Suspension USA (I can't find the ebay store I got them from, it was about 6 years ago or so). YSS and Hyperpro also do progressive springs and are easy to find. Anyway, I replaced the oil (which was like water) with Motul 10w fork oil (different brands have different viscosities, Motul's 10w is different from, say, Castrol's...it's a weird thing with fork oil.) That change transformed the front end of the bike, it doesn't dive uncontrollably, braking is better, it steers and feels nicer. Note that you might need to make up a new fork spacer if the new springs are shorter or longer than the originals. Mine were longer than standard so I'd to dump the steel spacers which were in there originally and just cut some PVC pipe to act as new, shorter, spacers.
I had the original Showa rear shock rebuilt by MCT in the UK for about €220 back in 2015. They did a fine job, although I don't think the shock was that bad in the first place. I don't know if there would be import duties on used parts which are being refurbed - check that out.
As for PVC pipe, just go to a DIY place and look for white PVC pipe like you'd use to connect up a sink/basin - cut that in half, use a couple of hose clamps to keep them together around the upper fork tube and then use those as a slide hammer to pop the new fork seal into place (use the old seal as a cushion so the PVC isn't hitting the new seal directly). I'm not a huge fan of this guy's videos but this explains the process pretty well with home tools, nothing fancy:
This one is also good:
