Center stand removal
15 posts Started 24 Apr 2021 Last recovered post 30 Apr 2021 Wayback Machine snapshot 10 May 2021
My '14 coming with front and rear Dynamoto stands, I see not much use to the center stand once I master their usage safely. Is it true that the exhaust has to be removed to ditch the ctr stand?
5 hours ago, chutta
Yes!
Don't forget the left hand thread on the right hand side.
Plenty of use for the centre stand when you’re on a tour and need to repair/replace a tyre.
2 hours ago, VFR78
And for chain maintenance . . .
Thanx for the reminders of the maintenance issues. A reasonable tradeoff for the stand scraping first
chutta, 4/25/2021 at 6:04 PM
I guess it depends on what you use the bike for. If track days are your thing, then the stand should probably come off. If you use the bike for sport  touring, it should probably stay on.
Yes, now I have the gear necessary for track days other than needing a new front tire. After watching 2 crash within 20 minutes at the end of the main straight at Grattan in the expert class, my thoughts at partaking dim at the prospect of bashing my VFR at 66 years old
For track days, you can zip tie the center stand to the frame so it does not bounce around (mine just hit the ground in a turn while hitting a bump, I hate that). The weight saving without the c-stand is negligible.
1 hour ago, Wald
And it's weight that is well below the bike's center of gravity,  so it has little effect on handling.
7 hours ago, chutta
I’m booked in for a track day in October and I’ll be 69 then. Starting to think I’ve lost my marbles. Crashing the Viffer would be heartbreaking, crashing a 69 year old body might be more permanent.
You will be only on paper 69! In your mind you will be as old as you decide to be!
A good friend of mine is 74 and still does crazy mountain bike rides and still crashing once in a while but it does not stop him (now with the help of a monster e-bike he still kicks a**!)
!!!live before you die!!!
That’s the plan, as long I keep my marbles!
12 hours ago, VFR78
Good on ya VFR78 I'm not far behind you.....in age that is. Enjoy the track day, don't worry, you're no doubt wise enought to keep things in check, just don't over stretch that throttle cable ya hear!
Cheers. :fing02: :wheel:
Hopefully the red mist stays in the garage!
End of thread · 15 posts recovered Wayback Machine snapshot 10 May 2021
