Hi when i cleaned the jets the main jet has a hole all the way top to bottom,but the slow jet i think its called ..when i tried to clean them i could,nt see right through on all 4 of them is that right? even if i tried to with a pin do they work differently? the holes on the side and very bottom all ok and clean.Or do i have to take apart again ?
carb jet question..
6 posts Started 16 May 2021 Last recovered post 24 May 2021 Wayback Machine snapshot 5 Aug 2021
If you have the carbs apart then get 4 new #40 jets to replace the #38 that are in there .... it’ll tickover much better
Hi all back together at the moment but wont take long to pull out again where to buy replacement jets? like i asked do those jets have a hole all the way through im not clued up on carbs really
yes, jets have a hole from top to bottom.
Just now, squirrelmanyes, jets have a hole from top to bottom. on #38 and 40 idle jets you should be able to pass a .010" steel wire clear through if the jet is clean.
End of thread · 6 posts recovered Wayback Machine snapshot 5 Aug 2021
