VFR Discussion Group -> Anyone Had Their Headers Coated
24 posts Started 19 Jan 2005 Last recovered post 11 Mar 2005 Wayback Machine snapshot 30 Apr 2005
I've searched the archives, and read that ceramic coating on headers will help keep the heat from escaping from the header, and pushed on down the pipes.
Has anyone had this done? Is it a mod worth doing?
Any info would be of great help.
Jim
Personally I never had a problem with excess heat from the pipes.
So I gotta ask why bother? :unsure:
Spend the money on something noticeable. Suspension upgrades, Nitrous oxide... :D
Thanks Lee. I'll look into doing something else.
Jim
I had my headers ceramic coated because they were starting to look pretty shoddy. Whether or not it will make a big difference in performance won't be known until I dyno the bike later in the year.
After the coating, did the headers chip less, and how do they look?
Jim
Haven't put any miles on them yet, but they look great. Very close to chrome, but not as reflective and won't change color like chrome does.
I know a guy that lives in DC, and rides in winter.
He had his JEt Hot coated, ( around $ 125) and is pleased over 1 year later
Jet: If this has to do with your pipes turning blue, then there is a product called Blueaway that may help, but I have not used it yet personally.
SAFE-T, Jan 25 2005, 07:18 AMHaven't put any miles on them yet, but they look great. Very close to chrome, but not as reflective and won't change color like chrome does.
Pictures!! We need pictures!! :beer:
I used ceramic based aluminum rattle can, then baked them in a big oven (Why's my bacon taste funny?). The finish worked well for the first season, but is starting to corrode through in some spots. Not worth doing the cheap way, due to PIA factor. But the silver finish looks cool. Probably worth doing in Jet-Hot.
[image: Attached Image] [image: Attached Image]
On my VTR, I had the headers coated by Performance Coatings. Not very expensive and seemingly pretty effective as a thermal barrier. It was a great cosmetic upgrade as well but the headers were hanging out in the open on that bike. I haven't had my VFR long enough to figure if the right foot gets hot from the headers but that might be a legit application if the headers cook that foot.
I recently had my header ceramic coated in satin black (sorry SAFE-T) and finally installed them tonight. As you can see in the before and after photos, the coating makes a big difference. I've not yet fired her up to check pipe temps, but anything can help. Maybe it will contain some of the heat flowing around the R/R.
Looks great. :beer: Now what would something liek that cost to have done?
Indy Powder Coating did it for me for $150. That included prep and coating. Turn around was about 8 days.
sa1713, Jan 19 2005, 06:18 PM
Heat from the exhaust pipes use to blister my thighs on hot days... then I wrapped the exhaust pipes in Kevlar to shield my skin... it worked so well that I offer to wrap every RC45 that comes through the Busy Little Shop...
(IMG:http://home.comcast.net/~netters2/pics11-3-03/bigimages/RC45ExhaustWrap.JPG)
Larry, where do you get your wrap from? Is it expensive>?Looks kinda funky :thumbsup:
dude, Mar 7 2005, 08:23 PMLarry, where do you get your wrap from? Is it expensive>?Looks kinda funky :thumbsup:
It's item 11021... 1" x 1/16 x 50' graphite wrap...
Cool-It Exhaust Wrap
Get it wet first and then wrap it tight and hold it with safety wire...
Header wrap is definitely effective in containing heat but other board members have noted it needs to be kept dry, otherwise it traps moisture against the pipe and mungs them up pretty bad.
The satin black coating is rated to 2000 degrees F, so it should at least hold up better than the factory finish, which was totally burned off mine - the rear header pipes looked 20 yrs. old when I took them in :(
SAFE-T, Mar 8 2005, 09:37 PMHeader wrap is definitely effective in containing heat but other board members have noted it needs to be kept dry, otherwise it traps moisture against the pipe and mungs them up pretty bad.
That is what i read too in a car forum.
Wait a second, here, guys : How could water keep from flashing to steam on headers that normally operate at 500 to maybe 700 degrees F.?
Yes, the heat wrap gets wet from splash...but surely it drys within seconds--or less!
Hard to see how that could contribute much to corrosion.
Best regards,
BurmaWolf
Sleep in a chair
Nothing to lose
But a nap
At the wheel
Is a permanent snooze
--Burma-Shave--
If you store the vehicle with a wrapped header pipes in a moist enviroment, the header wraps will retain moisture in the moisture in the air, since your vehicle is not running and the headers are cold.
Hey gang
I haven't posted much, but i want to share this. I am aslo in the process of having the stock headpipe coated, but i noticed some room for improvement first. I'll try and attach the pics, but i cleaned up the welds at the flanges, should help alittle. Also if you gettting a hot right foot try some adhesive thermal barrier on the inside of that little gray cover down by the footpeg, that made a big difference!
ok i got Upload failed. You are not permitted to upload a file with that file extension
they are just jpegs, any help?
My '94 came with a coated header pipe, not sure what process. After the three years that I have had it, it still looks great. One of the front pipes got a chip on it but I have let it go for 2 years without an noticible increase in size/corrosion. Probably have that pipe recoated next winter.
Course I would trade it all for a two bros. header....
End of thread · 24 posts recovered Wayback Machine snapshot 30 Apr 2005
