Now I've had my new-to-me 2000 for two months. As with any used bike purchased, one always wishes for more information about its past life and what's been done, but that's just life.
I've put on about 1500 miles so far and the bike has been a mixed bag.
It arrived with 30K miles and in very good overall condition. I like to look for tells on what level of attention a bike's gotten, and this one sports Galfer stainless brake lines. That's always a good sign to me, one of the better ones.
My take is that the previous owner rode it some but less in recent times. It starts perfectly and idles well, albeit right at the high side of spec and can't be adjusted any lower.
The throttle response is good all across the range, although I'd rather have less snatch in the first portion of the range, like pretty much everyone else.
So far I have two main problems with the bike, the first being the ergos, specifically the bars. They are simply too low and far forward for me. I'm not as flexible as I once was and have an old neck problem that hasn't allowed me to use lower bars since the mid-'80s. I've installed longer throttle cables, rerouted the brake and clutch lines, pulled out more length on the handlebar switch leads, and am experimenting with higher bars.
But the bigger bug is the vibration. I'd been told many a time how smooth the VFR engine is, but this isn't the one. Now, I'm no sissy- I put 50K on a BSA twin once upon a time- but the hands are taking more of a beating on longer highway stretches than I care to take. Specifically, at 70+mph, it's enough to bring discomfort.
On a conventional four-cylinder, such as the ZX-9R I sold to buy the VFR, one starts with a valve adjustment and a carb/throttle body synchronization. On this bike, the valves ought to be near enough to spec since they were supposedly done at about 17k and are only coming due now, and I am not seeing a TBI sync procedure in the factory manual.
I have some ideas, but I would look to the conventional wisdom first to decide on a path. GIven that there's a half-dozen other bikes in the garage, there's only so much wrenching time to be had.
For heaven's sake, the Missus has just informed me she's interested in a GSX-R600 front end graft on her SV650S. If that isn't an inhaler of time, I don't know what would be (besides a BSA crank bearing upgrade job).
