Walker1, 7/17/2021 at 11:58 AM
BusyLittleShop you legend. Got the bugger off. Put the nut on, gave it a belt and bing bang boosh! Lots and lots of corrosion.. the inside of the sprocket looking not so good nor the axle itself.. any tips to clean these bad boys?
Here are my axle care notes that I send out to RC30/ RC45 owners...
you'll have to download the photos for the lesson to make sense...
Because the RC30 and RC45 employ the same caged needle bearing the
rides directly on on the rear axle I offer my method to clean both the
axle and bearing...
[image: gallery_3131_51_61974.jpg]
Once you have the bearing removed you employ a two jewelers screw
drivers and carefully lift each roller from the cage...
[image: gallery_3131_51_49199.jpg]
Give the rollers and cage a bath in gasoline... you be surprised at
all the dirty deposits hidden in the old grease and every nook and
cranny... you're looking at the deposits after only 10K miles of
normal operation...
[image: gallery_3131_51_47395.jpg]
Once the bearing are really clean lay them out and inspect each roller
for scoring...
[image: gallery_3131_51_41593.jpg]
Dirt mixed with the old grease will leave a trail of deposits on the
axle at point B...
[image: gallery_3131_51_14606.jpg]
Spun in a Lathe... it's easy to remove the deposits employing a gray
micro fine 3M pad... it's soft enough that it does *not* remove any
precious metal... employ a soft wire wheel to bring the other parts of
the axle back to a luster...
[image: gallery_3131_51_40032.jpg]
What you'll end up with is an axle with the deposits remove plus
giving the metal a nice luster...
[image: gallery_3131_51_39038.jpg]
