If they will latch without locking, I wouldn't give him a key. Tell him it is to protect him as much as anything because if your bike is ever stolen, he would be the OPP's #1 suspect. Even if they won't latch without locking, I don't think I would.
Swapping the (GIVI made) locks on 6th Gen cases is a piece of cake.... Dunno if they are with your model but it should be fairly easy with the case open.
And no, I would not give him a copy of my ignition key.
Don't the locks have the key numbers on them? Nothing stopping him from getting your "ignition key" made, even without the number. Someone who drives 4 hours for some hard bags is not casing your joint. And if you meet him somewhere, he doesn't even have your address. Make his life easy for a while.
Thanks to everyone who chimed in. I'll be a good samaritine and meet him at the local Homehardware near my house and we'll exchange the bags there and he can make a duplicate key with his blank.
My suggestion would be to remove the locks for him. Making a copy of the key is not needed if the locks are out. He can re-use your lock insert, and just needs to order and install the pins this way.
Exactly. This is the best option for both the buyer and the seller. The buyer will then be able to have a set that uses the same key as the bike.
End of thread · 11 posts recoveredWayback Machine snapshot 28 Jan 2022
