Will a Gen4 gas tank and seat fit on a Gen3?
50 posts Started 27 Jan 2022 Last recovered post 1 Feb 2022 Wayback Machine snapshot 6 Jul 2022
Trying to explore options for a gas tank and seat for my 91. The eBay Gen3 gas tank was a bust, the seller didn't pack the box up properly and it arrived damaged. Gen4 gas tanks are more readily available as well as the Gen4 seats. The gas tank mounting tabs look to be the same as Gen3. Is it possible to swap the gas tank and seat from a Gen4 to a Gen3?
Just a recap, my 91's gas tank is badly rusted inside, rendering the petcock and fuel level sender completely unusable. The gas tank will need long therapies of electrolysis to clean up, which I will attend to. I was looking at eBay used gas tank hoping to find one that's not rusty and with a petcock and fuel level sender(I know it is available new). Looking at a seat as well because I am very short legged and need to shave the seat. I would rather not shave my original seat that is in good condition.
I happen to have a 1990 and a 1995 with all the bodywork off right next to each other in my shop.  I'm not optimistic.  The mounting styles are similar, but the way they mount it has to be EXACTLY the same.  The mount locations are all the cast aluminum portions of the frame.  Now bring in a seat and there's even more variables.
No 4th gen came in the same red as the 3rd, so you would have to repaint.    So if the tank you got is clean, why not bite the bullet and have it fixed and painted?
Your bike deserves to not be a mash up.  It's fucking nice.
2 minutes ago, Captain 80s
I always keep my bikes original or with original parts as spares if I am modding it. It's another reason why space is an issue with a limit of 10 bikes 😂 The original gas tank will be de-rust, it is just going to take some time before it is done. I totally agree with not mashing it up. It is the riding itch talking here 😅. I am just trying to solve the gas tank and petcock dilemma with more options quickly so I can ride it.
Since I got the bike fairly cheap, I could bite the bullet and buy a brand new gas tank for $600 but I would still need a working petcock to ride.
Have you drilled out the rivets and opened the petcock? (I forget)
Yes, the pivot shaft is badly corroded and does not provide a seal even with a rebuild kit. I guess last resort I can try to JB Weld the shaft and grind it back into shape but how long will take work with gas?
Long enough to come up with your next solution while you ride it.  And the fuel pump is back down below the carbs, as long as it's not leaking out the face it doesn't matter if it won't shut of all the way.  There is no way your gonna gravity-push fuel through the pump and back up hill and then overcome the float valves in the carbs.
Put a high quality fuel line quick-disconnect for when the tank has to come off.
4 minutes ago, Captain 80s
That is one of the options to overcome the leaky petcock. Saw a post on here with one that fits.
In the meantime, I am looking on eBay and other selling sites. If anyone is selling a R157 gas tank with petcock or just the petcock please let me know. I just need to find enough stay at home time to start the electrolysis where I can keep an eye on it while it cooks
I know none of those are actually great, but they are the ones with hardware.
Would like to see inside the one with the cap.
10 minutes ago, Captain 80s
The problem is I prefer not to repaint or repair dents. At that kind of $$$, I would rather pay the $600 and get a brand new R157 tank.
I would be willing to pay for just the petcock but there is no way to know if it is still good
1 hour ago, DesertKyorugi
There have been thousands of cager fuel tanks permanently repaired with JB Weld.  The shaft is a moving part so it won't be permanent, but if you can get it shaped well enough to seal, it will last a while, especially if you aren't turning it on and off all the time or having to hit reserve a lot.  I never turned my little 500 Interceptor off except when I parked it in my apartment bedroom for Christmas break one year, but I did have to hit reserve pretty often. lol
16 minutes ago, Captain 80s
Where can you buy a new tank?
I have a friend who works for a parts warehouse. He found a R157 NOS gas tank for about $600 plus tax. I think it is at a Honda dealer in FL
I can't believe this thread isn't "Check out my NOS tank" then.
Think I'd make a fairly thick block off plate (to replace the fuel selector and cover, not eliminate the petcock) and seal it with some 1/32 viton sheet rubber.  Then use a quick-disconnect.
LOL, I am cheap plus I haven't ridden this bike yet. The carbs will go on today, I might have the engine running.
Also, I have a money pit project going on right now restoring my 70 CB750K0. Just bought the full body kit for it, the $600+ for the NOS gas tank will have to wait since the original gas tank is totally restorable
20 minutes ago, tbzep
JB Weld is right up there with PB Blaster and E6000, and it is impervious to fuel.
Cheapo track repair on creased tank w/out leaks.
I'd get that NOS tank on teh way...packed properly and insured.
34 minutes ago, Captain 80s
Oof, found a NOS petcock for $129 plus tax and shipping........
3 minutes ago, Captain 80s
You HAVE to buy that Petcock.
It is more than twice the cost of an original Honda CB750 petcock but seeing that it is an unobtainium, I went ahead and order it. Hopefully there is no mistake in it being the correct item 🤞
Now that you ordered it, where did you find it?
It came to about $150 with tax and shipping 😢. I ordered it through my buddy's connection. He's my source for unobtainiums. I didn't ask where this part was found
Very cool.  Money well spent on a piece of the puzzle.
That tank is a better investment than ANYTHING else right now.  Jus sayin
I hear you. I am trying to figure out how to cover my tracks as we speaks.........ran out of slush fund already
Well, just for the pedants among us...the ROW 3rd gen red in 1993 was R-158P, the same red as the US 4th gens.  My UK-spec '93 is that colour.  However, I also have a US-spec '90 in parts, and have a full set of NOS R-157 plastics as well as a couple of tanks and I'd have to say that you'd be hard-pressed to tell the difference between the R-157 and R-158 tanks.  You try:
[image: 20190901_111750.thumb.jpg.f4939620e92c741a589471939a93f85a.jpg]
[image: 20190901_111819.thumb.jpg.60c085b9b095aa177b5eaf0d886a4a2b.jpg]
Which one is the R-158P?    :happy:
JZH
Right looks darker.
Are the safety stickers also different?
158 has more pearl in it.  The right one looks "deeper"
I am new to the VFR so I don't know much, but I think my R157 is the one on the left. The one on the right is darker
Well, she runs beautifully. The rebuilt carbs went on easily with a little coaxing from the heat gun. Mixture screws out 2 turns with the #42 pilot and one shim.
The gearbox is nice and smooth, no trouble getting to neutral.
Now I just need to start electrolysis on the tank. Hopefully, I get to ride it soon 🤞🏼
PXL_20220128_202301037.mp4
Sweet!!!!
It's a little too quiet though 😅 How is the exhaust slip-on adapter project going?
Just now, DesertKyorugi
I got some pieces in and I have 2 or 3 very promising options.   I'm hoping to also install my carbs this weekend and verify the engine.  And then I will hack off the muffler and start to fab up.  Will update.
3 hours ago, Captain 80s
I have a local guy selling a Vance and Hines SS2R slip-on. $120 Supposedly from a 93 with all mounting hardware. Any good? Need rejet?
Its a quality unit.  Your #42 pilots will compensate nicely.  No need for bigger mains with a slip-on.
If you like the looks and its in good shape, thats a good deal.
8 hours ago, Captain 80s
Perfect, I bought it already LOL
It's in like new condition. I hope it is loud enough when need to be
Wow!...   slush fund made a miraculous recovery.
33 minutes ago, Captain 80s
Sold the Yoshi exhaust for more, buy the Vance and Hines 🤑
You say "the Yoshi", like we know wtf you are talking about.
Selling a few more things tomorrow and the slush fund should recover enough to buy the NOS tank
And....still...  what is "the Yoshi"?
The Yoshimura slip-on exhaust that I asked you about in another thread
It is interesting. I knew what you were talking about, but never heard Yoshi. Only Yosh.
4 hours ago, bmart
Yoshimura is actually two words, Yoshi is good or lucky and mura is village or town. Yoshi is also the name of the cute dinosaur in Super Mario World.
It's always been Yoshi in my Asian circle
Oohhhhhhhh!   Hah!  Sorry, I'm an idiot.   I knew you were talking about a pipe, I just totally forgot that's why you were interested in an adapter.
Cheers!
DesertKyorugi, 1/31/2022 at 12:36 AM
Yoshi in Australia too. Usually said in reverent tones when in the presence of a Suzuki TL1000R with full Yoshi system.
Me and my friends will use either.  Probably a little more Yoshi.
End of thread · 50 posts recovered Wayback Machine snapshot 6 Jul 2022
