12 hours ago, bmart
Not sure if this is contributory or not, but...
If air was getting in the system, and you checked the level/overflow at that point...then ran the bike, air is likely to end up in the overflow with the fluid going into the semi-sealed system in the bike.
Air in the system will also make it run hot. If you get enough air in, the gauge won't read hot (not fluid to read).
I think I understand and that makes sense. The level dropped from upper to lower first while bike was stored after first round of work in 2019. Apart from starting the bike in the drive then and rechecking level, it wasn’t ridden. I topped it up, only road it about 20 miles for its annual inspection. Noticed level was back at lower shortly after that.
I wonder whether I just did a really bad job on the coolant fill last time. Perhaps poured too quickly and got too much air in. I followed the Haynes procedure for burping, but it seemed a bit quick (run for three minutes and blip a couple of times to 4000rpm).
Filled very carefully/slowly yesterday and noticed a fair amount of gurgling etc. Running the bike briefly did not drop level, but it had dropped a little (in the filler neck) after an hour or so sitting.
It is possible air has been getting in as you say, but there’s been no (or only a single drip) coolant visible on the floor anywhere it’s sat.
I can finally ride it now as this is the last job that I know needed doing (I also have a breakdown/recovery policy ;-)), so I guess I’ll find out a lot more soon and will monitor temperature and for leaks very carefully.
12 hours ago, trmoyer
It’s always a win in my book when a job works out like this! No catastrophes, no broken parts and you didn’t lose and fingers. Yep it’s a win. There will always be someone that’ll come along and say they would replace hoses and clamps but if it works for now then it works.
I have a laundry list of wants / needs for my bike. When I get to certain things then I get to them. If it’s not broke or dangerous then don’t fix it, yet.
Thanks, tried to document as I could find too much about how to do the job online. Very happy to have any one suggest improvements here since these threads hopefully will help others in future.
Thankfully hoses I can see are in good condition (firm but pliable, no cracking or crazing). I know that at some point I’ll need to do a full check of the hoses in the vee. Provided things run normal now, I’ll defer that to a more convenient time.
Did start looking at replacement hoses, but they seem to be unobtainium at the moment. As3 kits are all shown as out of stock apart from wax unit hoses (which my bike doesn’t have). Looks like twice the price Samco are available as long as I don’t mind ruining how it looks with red or blue hoses.
As far as I know now bike is good to go (famous last words).
