Hi, all! I'm in the process of building a set of variable length velocity stacks. Inspired by mohawk's yoshi style velocity stacks and variable systems built by MV Agusta and Yamaha I've decided to do something similar on my '02 VTEC.
I bought a whole other airbox, with velocity stacks included. 6th gen comes with two long and two short stacks, so I have 4 of both. The long ones are repurposed to be fixed at the bottom, this way the bore diameter is increased and the length of the stack is reduced. The short ones will be kept stock and made to move up and down. When down they will insert into the bore of the bottom ones. The length and bore diameter in lowered position will equal the original long stack. When in upper position the upper stack will move above the lower stack. In picture below is the initial idea. I have much longer bolts now that will enable the upper stacks to move up to fully clear the bore of the lower ones. The bolts have threads only on the bottom. The upper stacks have these hollow cylindrical pieces inserted in bolt holes. This enables the upper stacks to slide up and down on the bolt.
[image: image.thumb.png.d12c788a967c00208b1e18e9d5c5c241.png][image: image.jpeg.8ece16156c981604e659f60fddf99675.jpeg]
I cut off the radius part from the longer stacks and made them flush with the bottom of the airbox. I used dual compound epoxy to glue them. After curing I used a file and sandpaper to match the holes of the bottom of the airbox to throttle body bores. That is the bottom part done.
[image: image.thumb.jpeg.c7fbac6bf660d5c8ddaab1fe55526c8a.jpeg][image: image.thumb.jpeg.d9c26694d3b0b902f5c7e752c346ddc7.jpeg]
For the movement I decided to repurpose the flapper assembly. I glued the vacuum diaphragm actuator upside down in the middle of the airbox. It clears the fuel rails and connectors beneath with no problems. It has about 12mm of travel, but I need around 25-30mm of travel so that the upper velocity stacks fully clear the bottom ones. Because of that I decided to use a lever system. This way the movement is reversed and the range is extended. I drew a schematic of how it will be done, only one side is drawn for simplicity, but it will be simetrical. The lever system will be mounted on a metal U shaped profile (red), bolted to the bottom of the airbox. A bolt (cyan) will go horizontally through the U profile and the lever arm (green) will rotate around the bolt. The lever has rotational movement, while the actuator and the movable stacks have linear movement (yellow arrows). To solve that problem I will simply drill the holes in the lever arm that are wide (the ellipsoidal shape of the holes in the schematic). There will be a bracket to connect the front movable stacks together (cyan). Same in the back. The bracket will slide on long bolts. I intend to intercept the VTEC signal and use it to activate a relay, which will activate the flapper solenoid. The original signal for the flapper activates at 5500rpm which is too early.
[image: image.thumb.jpeg.63dee45d224271bb48506766d4e299f9.jpeg][image: image.thumb.png.2dbe7e2260d6113e958b344af90c507a.png]
I will update the thread with more details when I take more pictures. I'd like to know your thoughts on this mod, if you have any ideas to improve the design feel free to share them. When I finish the build I intend to test the stacks. I can assemble a stockish setup with 4 short original stacks. That will be the baseline. Then I can compare it to the modified setup. I will try to bring it to a dyno. If I can't get it dynoed I have an idea to do 3rd gear pulls from 3000rpm to limiter. Time every 1000rpm segment from video or from Rapid bike logger and compare gains/losses.
