Ducati rear wheel conversion RC36-2
8 posts Started 23 Jan 2023 Last recovered post 11 Feb 2023 Wayback Machine snapshot 25 Mar 2023
Does anyone here have experience converting a Ducati 888 rear wheel into a Honda VFR750 RC36-2. I myself am thinking of using a Honda VFR400 NC30 rear hub for this. Should this be possible? Any help would be appreciated.
I think you meant to say Ducati 848 rear wheel as 888's do not have single sided swing arms.
No personal experience with RC36-2 single nut conversion. The only RC36-2 single nut conversion I've seen is on Intagram from Japan (https://www.instagram.com/p/CTHWb3xnjeN/)
Don't know what he used, though judging from the size of the nut, looks like a Honda rear hub (https://www.instagram.com/p/BDImq_KEYl6/)
You might try a pm to @SEBSPEED. Pretty sure he will have be in the know.
Captain 80s, 1/23/2023 at 9:17 AM
Having the spindle (and/or wheel) modded for different wheels has been done for a while over on hawkgtforum.  I had my Hawk modded for a VFR wheel and there has been plenty modded for Ducati wheels.
You might pop over there and poke around.
https://www.hawkgtforum.com/forum/honda-hawk-gt-bros-discussions/hawk-bros-vendor-area/927189-spindle-mods-by-ww-r
Hawk spindle is pretty easy to modify for Duc/VFR rear, but the VFR spindle is not.  I put a Hawk spindle that was modified in the Tyga 4th Gen, and could run nc30/35 or Duc wheel.[image: 554579821_vfr750(19)b.thumb.jpg.7ed60180ccadd05387a3efce3271da73.jpg]
Sweeper, 1/23/2023 at 11:59 AM
I have done the conversion using Triumph parts. I modify the wheel stub of the Triumph axle via machine/press fit/weld then add spacers and drive pins so it all can be bolted in the 750 swingarm.
End of thread · 8 posts recovered Wayback Machine snapshot 25 Mar 2023
