Lower A Gen 5 For Free
68 posts Started 16 Mar 2005 Last recovered post 21 Mar 2009 Wayback Machine snapshot 10 Jun 2023
Damn I wish I'd known this before. Maybe it would have allowed me to fit my Ohlins from my VTR which is about 21mm longer.
Rich A
dukeracr, Mar 16 2005, 04:41 PMDamn I wish I'd known this before. Maybe it would have allowed me to fit my Ohlins from my VTR which is about 21mm longer.
Rich A
It might have made it. I found this out by accident. I pulled out all the components to figure out how to temporarily lower my VFR so that the wife could see if she liked it. I was staring at all the parts on the bench looking for a quick way to extend the dogbone, when it hit me. The triangle plates are not symmetrical, and the longer point can change the height. Not allot, but enough. Between that, sliding the forks up and running minimum preload, the wife is happy. BTW she has her own VFR. It only took one ride to get her hooked. LOL wheel.gif
Interesting! I didn't pay any attention to that when I changed the shock.
dude, Mar 16 2005, 05:35 PMI thought you were going to say "let some air out of the tires"  goofy.gif
LOL That works, but hen you have to get them rotated so the flat spot is on top. biggrin.gif
Just where are these triangle plates located? If I go out and look at the rear of my bike will it be readily apparent as to where they are? Just what do the hold up/on?
Kurt V
[image: vfr%20dogbone%20and%20shock.jpg]
I found out that if you remove the triangle shaped plates in the rear suspension and rotate them, you can lower the rear of the bike about 3/4" for free and in about 20 minutes. My wife who is 5'2" can now ride her bike and reach. I also have mine lowered so I can run my preload a little higher.
[image: gallery_7263_1384_254692.jpg]
suspension plate mod
baileyrock, Mar 16 2005, 10:13 PMKurt V
baileyrock, Mar 16 2005, 08:13 PMKurt V
Thanks for posting that.
Kurt VThanks!
<{POST_SNAPBACK}>
There is an arrow that is suppose to go to front. I think it ended up pointing up, but can't remember for sure. Basically you want the short point going to the shock, and the long point going to the dogbone.
Since I have a '00 with the stupid cat. conv. will it still work? The cat. has an indentation where one point of the "triangles" would have hit it. The gap between the both of them is very, very close.
Finleyville, Apr 13 2005, 12:46 PMSince I have a '00 with the stupid cat. conv. will it still work?  The cat. has an indentation where one point of the "triangles" would have hit it.  The gap between the both of them is very, very close.
I can't say for sure (both mine are 98's). I would say try it, and if it hits you'll know probably before you even ride it. That triangle doesn't move that much with the suspension. It only take about 10 minutes to do it.
Brad,
Thanks for the pointer, this worked like a charm! :thumbsup: Between modifying the seat foam and lowering 3/4" the VFR is more comfortable for me. My 30" inseam doesn't let me flat foot most bikes, but now I can get both feet to the ground at the same time. The only thing to consider now is making the sidestand shorter - but that isn't too big an issue.
Thanks,
Kevin
Kevin1, May 16 2005, 02:36 PMBrad,
Thanks for the pointer, this worked like a charm!  fing02.gif   Between modifying the seat foam and lowering 3/4"  the VFR is more comfortable for me. My 30" inseam doesn't let me flat foot most bikes, but now I can get both feet to the ground at the same time. The only thing to consider now is making the sidestand shorter - but that isn't too big an issue.
Thanks,
Kevin
Cool, I am really glad you like the results. The side stand it almost to long with the sag set for a light rider. I just make sure my wife parks with the stand down hill if the are isn't flat.
I measured my "triangle" and found the following:
AB and AC are equal, and BC is shorter than both of those. Which two points should the shorter dimension connect in order to accomplish this lowering?
Thanks,
Payne
[image: vfr%20dogbone%20and%20shock.jpg] border='0' alt='user posted image' />
If I remember correctly, "BC" should be between the dogbone and the shock. I can't recall for sure, but will try to remember to look when I get home for lunch.
This is a cool and quick Mod, but will also affect the Link ratio of the shock in some way. Can't throw it off to much though, but it will be working the shock a little different. This was one of the things mentioned by Phil at AfterShocks when using a CBR shock on a VFR, they run a different Link ratio resulting in slightly different valving !
I think it's partly the VFR's link Ratio that requires a much heavier spring than most, not just because of the pigish weight ! :goofy:
:blink:
psealI measured my "triangle" and found the following:
Thanks,
Payne
<{POST_SNAPBACK}>
The arrows on the plates should point up and toward the rear.
ratfink, Oct 10 2005, 07:34 PMThe arrows on the plates should point up and toward the rear.
would you say that slidin 3/4 of an inch up the forks as well would be the correct thing to do?
rstefdc, Oct 25 2005, 06:03 AMvery interesting, having a 29 inseam, its a must for me!!  fing02.gif
That's what I did on my wifes's bike. Depending on your weight, you may want to keep the height as high as possible on the front. The front is what make the plastic rub on driveway curbs if the preload is set to low. I have the front of mine lowered that way about 3/4", and the rear was lowered as well, and I never had any clearance issues, but I ran the rear preload set pretty high. I have since then lifted the rear even above stock so I could get clearance for my exhaust.
I just got a 2002 VFR800 and am planning on getting the sargent seat to help me reach with my 30" inseam, I was interested in this change since you done have to buy a new dogbone or make any kind of radical change, my question is do move the triangle so that the shorter side is between the dogbone and the shock
or in the picture B and C is now where A and B were.
also I can almost reach now so these two changes hopfully will be good for me, would I also need to lower the front forks or can I elave them as is?
Thanks for and feedback
Tony
Tonys-G, Nov 21 2005, 07:46 PMI just got a 2002 VFR800 and am planning on getting the sargent seat to help me reach with my 30" inseam, I was interested in this change since you done have to buy a new dogbone or make any kind of radical change, my question is do move the triangle so that the shorter side is between the dogbone and the shock
Tony
I am not sure what your first question was, so I will just answer the second. It is best to go ahead and at least lower the front the same hieght as the rear. If you don't, you'll change the steering geometry and it will feel heavier. The VFR has plenty of clearance once lowered. The only concern is the lean angle on the side stand. Typically you can lower it too far without getting a new stand. If you rotate the plates, and lower the front about 1/2" by sliding the forks up in the tree you should still be able to use the stock stand.
I wonder if i can do the same sort of thing with my 87?
what i would give for the bike to be just a half an inch lower!
You want the arrows pointing up and toward the rear. So, from the left (sprocket) side of the bike, rotate ~120? clockwise.
I didn't move the fork tubes, and the bike feels the same to me as before, so I'll probably leave them as they are.
I'm pleased with the results. Can't beat the price (free!), and the drop is noticeable, but not drastic. Very quick and easy to do (though the bolts took a ton of force to break loose), and completely undoable. I found that this increased the sag, so I bumped the preload up a couple of clicks. I'm a little nervous at how upright the bike sits on the sidestand, but I think it'll be OK.
Cheers to Ratfink for pointing this out to us!
Payne
There's another potential option, which may be used in conjunction with the "triangular plates method", or on its own.
On the Gen5 VFRs, the eccentric in the rear hub is positioned so that with a normal chain/sprockets, the eccentric is below the swingarm. There was a mod publicised some time ago for earlier model VFRs that involved reversing the eccentric so it was in this position, which had the effect of raising the rear of the bike and quickening the steering somewhat. I tried this on my 1990 VFR, and it worked well, raising the rear by (IIRC) about an inch. I'd imagine that the reverse is possible, and that rotating the eccentric on the 5th/6th gen bikes so it is in the 'normal' position for the earlier generation VFRs would lower the rear by about an inch.
I have a suspicion in the back of my tiny mind though, that there might be a problem with some bolts somewhere in the hub blocking complete rotation. This wasn't a problem on the earlier models, but IIRC it could be on later models.
Worth a try!
Oh - and before someone asks - the procedure is:
1. Loosen the pinch bolt on rear hub.
2. Rotate the eccentric adjuster to loosen the chain, but keep going, and going.
3. Eventually (if there's no bolts or summat else in the way), the chain will start to get tight again, as the eccentric passes the horizontal plane and starts going back up past the swingarm.
4. Adjust chain to correct tightness.
5. Tighten pinch bolt.
Of course, if there's some impediment to all this, ignore steps 1-5.
Yesterday I rotated the triangular plates per the instructions and yes the arrows do point up and to the rear. I have a 30" inseam and prior to the change the best I could do was my toes touching the ground. After the change I can easily rest the balls of my feet on the ground. Makes a huge difference when backing the bike out of the garage!
Saw this thread. Does it work for 2004 (6th gen)? Anybody try this yet
Should, they use the same shock linkage as far as I know.
chris2992, Feb 7 2006, 10:42 PMShould, they use the same shock linkage as far as I know.
Dealer did it to my 2005. Worked great. Lots lower for me, especially when combined with Sargent's work on my seat -- lower and more narrow at the front.
Did it and I'm more confident now.
I can just get my heels on the floor now.
I did soften it to number one
and softened the front to the third ring too.
I rotated the damping of the rear shock completely out (ccw)
Did I do something wrong? I'm trying to get the bike to steer better at lower speeds, short turns, but cannot seem to find the right setting yet, without compromising comfort.
(Still a beginner)
?art West-VL.Thanks!
(Still a beginner)
If you drop the rear but not the forks it will feel light up front, like its not hooking up, steering will suffer. You will have to crank off some preload up front to get it to feel right again, basically lowering the front along with the back. I have no idea how much you dropped the rear so I dont know how much to drop the front to match it.
AB and AC are equal, and BC is shorter than both of those.? Which two points should the shorter dimension connect in order to accomplish this lowering?
Thanks,
Payne
<{POST_SNAPBACK}>
The distance between A and C should be a constant, and since A/C and A/B have the same distance, rotate the triangle 120 degrees so point A on the triangle is at point C on the bike, and so on.
This may sound silly to some of you guys, but I'm gonna ask anyway..... hehe
I have been riding since I was about 12, and have done a lot of bike work, but never any work on the rear shocks.
Since I am a midget...... wink.gif I would like to try this quick lowering technique to see how it works out.
Is there any pressure on these bolts holding the triangular plates ? Do I need to block something, or place a jack under something before I remove the bolts ?
Thanks in advance.
Alfster
Alfster_1This may sound silly to some of you guys, but I'm gonna ask anyway.....  hehe
Thanks in advance.
Alfster
<{POST_SNAPBACK}>
put the bike on the center stand and put a 1x4 or something under the tire. It's makes it easier to get the first bolt out, and the first bolt in when you rotate it. You can use the 1x4 as a lever to raise the tire to the proper hieght and then either prop the 1x4 with something, or has someone else hold it for you.
?art West-VL.I did soften it to number one
(Still a beginner)
Yes, dropping the rear without dropping the front end the same amount will cause steering to slow by streaching out the forks forward. Can't remember if that's increasing or decreasing rake term wise. This is the opposite of what most people will do ! :warranty:
You want to set proper SAG to your weight for best/safest performance, not to get you feet on the ground. Removing all the rebound (CCW) from the rear shock will most likely cause some pogoing with no dampning to keep the spring for popping back up.
baileyrockYes, dropping the rear without dropping the front end the same amount will cause steering to slow by streaching out the forks forward.  Can't remember if that's increasing or decreasing rake term wise.
This will increase rake.
http://www.sportrider.com/tech/146_0310_art/
I did this mod last week and it works great, I plan to do the front this weekend, but I am unsure of how much to shorten the side stand. Does anybody know how much to take out and where the best place to cut is. I assume the best place is between the heel kick and the end of the stand, but if anybody knows better, please let me know. More importantly is how much to take out.
Thanks.
I also performed this mod today, it took me longer than 20 min cause I'm all thumbs. Having said that, if I can do it then anyone can.
I had to read thru the thread a couple of times just so I have it straight, there was reference to a photo of the plates but for some reason I cant view the images. So I took a couple of photos...a before and after shots.
Assuming I did this right, this is what it looks like.
[image: gallery_7263_1384_254692.jpg] border='0' alt='user posted image' />
The above procedure reduced the seat height by 1/2 an inch, so it does help those like me who are vertically challenged. With 30" inseam, I can now touch the ball of my feet to the ground after doing the mod.......now I have to get back in the garage and raise the forks accordingly.
Thanks for the useful tips.
borg
borgThe above procedure reduced the seat height by 1/2 an inch, so it does help those like me who are vertically challenged.  With 30" inseam, I can now touch the ball of my feet to the ground after doing the mod.......now I have to get back in the garage and raise the forks accordingly.
borg
Good going Borg, yeah, you got it right.
With raising the forks, beware your clearance between the front fender and the horn. Or at least I think the 6th gen horn is below the triple clamp like the 5th gen.
Anyhow, that is your area of concern. After raising the forks, when the bike is on the centerstand, take a floor jack, put it under the header pipes and lift the front end off the ground by a hair or two.
Measure the clearance between the fender and the nearest immovable object above. If it's more then 5.5", you should be fine. :thumbsup:
veefer800canuckGood going Borg, yeah, you got it right.
<{POST_SNAPBACK}>
Thanks for the heads up.
Didnt get a chance to raise the forks yeaterday since I got busy with family commitment, I'll see if can find time today to do it. Is there a particular thread you can refer me to so I can read up on how to PROPERLY raise the forks?
Thanks again
Kurt VEven after lowering the front, my '01 leans over just fine with the side stand. It is a bit harder to get on the center stand now.
<{POST_SNAPBACK}>
When I lowered the rear, it was a bit harder to get on the centre stand. But now that I lowered the front as well, it is damn near impossible. On flat ground with the side stand down, the bike leans to about 85 degrees... not too far off 90 which is very scary.
My forks were sitting at 41mm from the top of the tree to the top of the fork tube (not the top of the cap). I figured that it was around a 1/2 inch drop in the back so I raised the fork tubes 12mm to make it even in the front. Now the front tubes are 53mm over the tree.
I also want the bike to dive into corners a little quicker, and from what I read, I may need to drop the forks another 5-10mm to get it to react the way I want.
Is this taking things too far??? Should I just put the rear back to the way it was before, or should I lower the front end another 10mm??? Any advice would be appreciated...
Edited April 19, 2006 by MegaMan
I did the kickstand last night. I took out a piece about 3/8 of an inch long, that, plus the 1/8 inch cuts from the zip blade, takes the total shortening to 5/8 of an inch. Lean angle is now closer to 80 degrees... I can now sleep at night.
ratfinkI am sure you will find htat you don't need to lower front any further.
<{POST_SNAPBACK}>
By lowering the front, all I did was put the forks back to the stock angle, I rode the bike like this for the past 2 seasons but always wished I could flat foot it. I have been riding with the front and back lowered for the past week. I can now flat foot the bike, but the handling is exactly the same. To improve the handling I need to decrease the rake on my forks, which would be done through raising the rear, or lowering the front (more). I may end up raising the rear back to stock and getting my seat shaved so I can still flatfoot the bike. (or just shell out for a Sargent).
Just did the front to match the rear and I'm not noticing that big of a difference. I guess the next cheapest thing to do is have the seat shaved down about 1/2".
Well, I bit the bullet and spent $0.00 to lower my '00 VFR. Rotated the lower shock mount thingies (highly technical terminology for you lay persons) and slid the forks up in the trees. WOW, like magic...I can almost flatfoot with my 29" inseam! I guess I got the front lowered a tad more than the back because the turn in is somewhat quicker at slow speeds. Only got a short ride, hit a couple of nice "S" curves and nice on/off ramps for the local superslab and it steered slightly quicker, but still felt very stable. Tried a little low speed manuevering in a bank parking lot before everybody appeared to empty the ATM and thought I was on a much more sporty machine. The Viffer felt much lighter at low speeds!
I've been considering this for a few months and finally decided to try it because the spousal unit & I are taking the MSF Intermediate class next weekend. Yeah, here in SC we have beginner, intermediate and experienced classes. So many "goofballs" get a learner's permit and constantly renew it that they revised the beginner course and broke it into two classes. The beginner course uses their bikes and doesn't include the riding skills test. The intermediate course uses your bike and has the riding skills test. DMV "may" accept passing the intermediate course in lieu of a riding skills test administered at DMV but they don't have to. We're trying to get the spousal unit licensed so I will quit calling her "one of those goofballs on a permanent learners permit." :o
Hey Lizard,
I moved the forks only 5mm (0,2") up, and it doesn't feel any different (also did the "shock mount thingies" lowering thing <_<)
How much did you move the forks up, to feel the lighter steering?
This would really help me out because I will have to make new rings and want to get it right in one attempt.
?art
Bart,
I moved my forks up about 9/16" (14mm) and noticed an immediate difference turning at speeds less than 25mph. It was less noticeable at speeds over 35mph, but steers a little quicker than at higher speeds. Feels really good and makes the bike seem lighter at lower speeds while still being stable in the turns.
I know that sounds like a lot, but I rotated the rear lower shock mounts which lowered the back end about 7/16". I wound up with the front lowered about 1/8" (3-4mm) more than the rear.
?art West-VL.Hey Lizard,
          ?art
<{POST_SNAPBACK}>
vfI may be crazy, but i'll ask anyway.  I would like to lower my VFR further would you guys not suggest i prefab some more "triangles to lower the rear a further 1/2" ????
Any thoughts? :idea3:
It does alter the shock linkage ratio, so the leverage of the swingarm over the shock is affected.
Not sure which way, look further up the thread and there was some postulating on the effects.
lizard,
Thanks for the clear reply...
Would the lowering on a VFR 2005 also be 7/16 on rotating the triangles?
I thought I read somewhere on this forum, that it's about 20m lower for a 2005, can't remember for sure.
What did you do with the side stand? My bike already stands quite right up, a bit scary. And now that I will lower it even further, I was wondering how you, or someone else, fixed that with the side stand.
(Did everyone do it like MegaMan?)
Is a steering damper needed, when the forks are changed that much?
I think the bike might be more sensitive to shaking , when the angle of the forks is changed?
to be continued...
Bart,
I haven't addressed the sidestand yet. I'm probably going to shorten it because the bike seems almost upright.
I haven't had a chance to ride since my quick test ride on Friday night, it didn't seem like I would need a steering damper, but it will take more riding to see for sure. Weather looks good for the next couple of days, so I'll probably ride to work tomorrow & Tuesday. :D
?art West-VL.lizard,
to be continued...
<{POST_SNAPBACK}>
Hey guys I am 5'8'' and I could stand to lower my bike this way. But I want to make sure everything is right. I weigh about 170 lbs and ride mainly in very curvy mountian and country roads so the negative effect this mod may have on steering is important to me.
After I rotate the triangle bracket what should I do raise the front end ? Will my weight dictate how much please explain this for me in easy tersm I am new to mechanics of motocycles!
[image: gallery_5849_1271_244680.jpg] border='0' alt='user posted image' />
[image: gallery_5849_1271_77003.jpg] border='0' alt='user posted image' />
Edited May 18, 2006 by VFR666
Yes Rod,
It was you who inspired me in the first please, if I remember correctly.
I didn't have the chance to make such nice one's, mine are very crude, just a peace of tube and on that tube I welded something to fit the dip and the pin (sorry, english dictionary incomplete in my head wink.gif )
It looks bad when not mounted, but once in place, it's hard to even notice the thing.
btw, my ring's are 30mm high :o but the handle's are flush with the forks for maximum height, making the total drop on the forks about 20mm... hmm, memory overload...it IS originally 44mm , right? +1.gif It measure's 64mm from the top of the forks to the plate now.
Edited June 18, 2006 by ?art West-VL.
Weld you're side stand yourself...
Since I'm unable to start a new topic, here goes the next step I did;
'Shorten the side stand'...
I removed the side stand, cleaned it up real good and then started the modification.
First I cut off the lower end, then cut off a few mm the same way the first cut was done, whatever length desired.
I cut off a full cm! Because the rear and the front dropped quite a bit.
After the cutting is done, cleaned up the parts and grind a 45? angle to all sides, this is meant to fill up with the electrode, wich was stainless steel 316 in my case.
Just welding two part together, without this angled gap, wouldn't be strong enough!
The rest will be clear in the pictures.
O yeah, use Loctite, or something else, to secure the bolts and nuts!
Feel free to ask questions.
[image: gallery_6978_1750_29485.jpg] border='0' alt='user posted image' />
[image: gallery_6978_1750_22108.jpg] border='0' alt='user posted image' />
[image: gallery_6978_1750_13794.jpg] border='0' alt='user posted image' />
[image: gallery_6978_1750_17978.jpg] border='0' alt='user posted image' />
[image: gallery_6978_1750_13499.jpg] border='0' alt='user posted image' />
Just ad a bit of acid to get this effect, it's not importend but it shows the difference between the weld and the original steel side stand.
[image: gallery_6978_1750_11928.jpg] border='0' alt='user posted image' />
finished
[image: gallery_6978_1750_13583.jpg] border='0' alt='user posted image' />
[image: gallery_6978_1750_12113.jpg] border='0' alt='user posted image' />
?art West-VL.I can't pull the bike on the center stand anymore, without the help of someone pulling the bike backwards.
I lowered the back witch the 'rotate the triangle method' and dropped the front so it measures 64mm from the top of the forks, to the triangle plate.
What can I do?
<{POST_SNAPBACK}>
How's your technique? You need to:
1. Put foot on centrestand tang and push to the ground
2. Right hand under lifting handle above left pillion peg
3. Left hand on left bar
Now simultaneously push down with your foot, pull up on the lifting handle, and pull back on the bar. Normally this should result in a smooth controlled lift onto the stand with very little effort. As you are lifting higher the effort required will be more, but still manageable.
Edit: forgot to say, nice work on the sidestand mod!
Edited June 28, 2006 by The Phantom
I did my '02 today and I am very impressed with the difference. The back went down 3 cm (1.2 inches). We (and by "we" I mean the guys in the garage) then lowered the front 4 cm and now I can flat foot the bike. It feels completly different when I reach for the bars. Nice cheap mod!
To clear things up guys, the triangle linkage has to be rotated COUNTERCLOCKWISE?? Have we achieved a consensus on the height difference this mod does to VTEC models (I assume all models 02-07 have identical rear suspension components)? Also, anyone has the torque specs for the 3 triangle linkage bolts?
I'm about to do this to my 03, at 5'7" and 29" inseam, it's a must! By the way, when you guys measure your "inseam", you take your riding boots off??? Seems stupid but this makes a difference equivalent to the lowering mod!!
Thanks much!
Regards,
Bruckner
Edited April 25, 2007 by Bruckner
BrucknerAlso, anyone has the torque specs for the 3 triangle linkage bolts?
The triangle on the 4th gen is torqued at 45Nm or 33 ft-lb
I have a 2006 VFR800 and I got the rear lowered by rotating the triangle plates. I need help (picture guide) on to how lower the front forks via triple clamps.
Since this thread is open I might as well ask for some feedback........My 5th gen has been lowered by previous owner. I've been riding with the bike in it's current set-up. I'm 5'10", 200 lbs......I've had some problems with bottoming out the rear end when I hit a rise or unavoidable hole...stator screw has left a few scratches into rubber. Placing the bike back to factory settings, what difference will I notice besides the ride height adjustment? I regularly push the bike hard on twisties and most of the riding is done in that fashion. Thanks for any feedback.
Edited May 5, 2007 by SA2360
vfr.moua
custompcs37421I have a 2006 VFR800 and I got the rear lowered by rotating the triangle plates. I need help (picture guide) on to how lower the front forks via triple clamps.
Here's the link:
http://www.vfrdiscussion.com/forum/index.php?showtopic=29516
Thanks!!!! It's only one thing that I don't understand in the guide. How do I secure the front end? Can I do one side at a time and not worry about the weight pressure being released.
custompcs37421
vfr.moua
Here's the link:
I used the rear bike stand to balance the bike and a car jack under the header/engine to keep the front up. I don't know if you can do one side at a time but why not use a regular car jack and do both while you have everything supported? Hope this helps.
Another thing: You might consider shorting the kick stand as well. The bike will not lean as much as before and risk dropping the bike. Don't ask me how I know, but I know....
Edited May 4, 2007 by vfr.moua
McCleod
chris2992Should, they use the same shock linkage as far as I know.
<{POST_SNAPBACK}>
Just curious as to what the dealer charged you to make this adjustment to your bike. I could do this myself but would somewhat feel more comfortable if they did this as my bike is still under warranty.
thanks!
Eric
ALLSHOTUP
McCleod
<{POST_SNAPBACK}>
thanks!
Eric
I had this completed in Jan of '06 when the dealer was doing some other work on the bike; sorry but I do not recall the cost just for that. I doubt that it was much since they had it on a lift anyway. It looks pretty simple to do. I know that it did not take them long because it was a "last minute" request on my part and they finished up really quickly. Sorry I cannot be of more help.
All : I have read through this thread and would like to perform this modification as I am inseam challenged. After looking at my VFR (1998) I am confused.
1) There appears to be two plates on either side of the bike that need to be rotated. I can figure out access to the plate on the chain side of the bike but not the exhaust side. Do the bolts run from the chain side to threads on the exhaust side?
2) Based on the picture, am I correct that point “C” must be rotated counter clock ways to point “A”?
3) Does the front end have to be lowered (forks raised) along w/ this modification?
4) Can all this really be done in 20 minutes?
Thanks and if there are any members in the Northwest Florida area (Pensacola) that have done this modification, I would appreciate their help. I will pay for the cold beverages of their choice and even spring for a burger. :D
ratfink [image: vfr%20dogbone%20and%20shock.jpg]
Will this work for the 1993 vfr 750f as well?
Just finished lowering my 2006 VFR and putting bar risers on. This is a great little trick rotating the triangle. Whoever figured that one out is a genius. I also installed longer dog bone from Sigma Cycle at the same time. Dropped the rear 1 7/8". I put a hydraulic car jack under the rear sprocket and chain and removed the rear wheel. This made access to all the nuts and bolts extremely easy. Also the jack which was on the left side of the bike made it super easy to line up the holes for the attachment to the rear dogbone. Lowered the front an inch and put Sigma bar risers on. Also installed the shorter Sigma kick stand. I know this means that there is a 7/8" difference between front and rear with front being a little higher. Dialed up the preload in the rear shock a little and its fine. My 30" inseam feet are flat footed in flat shoes. Bike is now perfect for my frame. Handling is SWEET. I'm using the bike for sport touring so the steering being a little slower is no big deal.
End of thread · 68 posts recovered Wayback Machine snapshot 10 Jun 2023
